emjaiuk Frequent Visitor
Joined: Dec 06, 2003 Posts: 335 Location: North Surrey (TW17) UK
Posted: Fri Oct 21, 2011 11:13 am Post subject: Loss of suction on mount. Any suggestions? |
The windscreen mount for my 740 (A RDS mount) no longer stays stuck to the windscreen. Has anybody any suggestions to fix this?
many thanks
Malcolm _________________ Go740L App 9.510 Europe 985.8155
RDS_TMC mount
Home 2.8.3.2499 Win10 Home |
IanS100 Frequent Visitor
Posted: Fri Oct 21, 2011 12:12 pm Post subject: |
Buy another or use superglue! |
JimmyTheHand Frequent Visitor
Posted: Fri Oct 21, 2011 12:30 pm Post subject: Re: Loss of suction on mount. Any suggestions? |
emjaiuk wrote: | The windscreen mount for my 740 (A RDS mount) no longer stays stuck to the windscreen. Has anybody any suggestions to fix this?
many thanks
Malcolm |
The silly things first - you have cleaned the inside of the windscreen (a glass cleaner) & the bit that sticks to the screen. I find sometimes they need a bit of moisture to stick
You could look at one of the mats that have been reviewed here - which might allow a more permanent fixture to mount or might be worth looking at alternative mounts and see whether will take the active bit from yours _________________ J. |
Posted: Sun Oct 23, 2011 9:36 am Post subject: |
Thanks for the replies. I had cleaned everything with meths, and already have two brodit mounts in use for phones. As a last resort I phoned TT and they suggested a couple of drops of wateron the suction pad. Beleive it or not it worked
FWIW I purchased a set of two TT black plastic disks for the dashboard of my motorhome and car. Both of which the dashboard slopes slightly towards the windscreen, and the TT mount doesn't have enough adjustment to compensate for this.
RDS_TMC mount
M8TJT The Other Tired Old Man
Posted: Sun Oct 23, 2011 9:53 am Post subject: |
emjaiuk wrote: | couple of drops of wateron the suction pad. Beleive it or not it worked | I would believe it. I thought that everyone knew that you usually have to wet them to make them stick But what do I know? |
Calomax Lifetime Member
Posted: Sun Oct 23, 2011 5:46 pm Post subject: |
M8TJT wrote: | emjaiuk wrote: | couple of drops of water on the suction pad. Believe it or not it worked | I would believe it. I thought that everyone knew that you usually have to wet them to make them stick But what do I know? | Strangely enough my manual says to use it dry, and it did work when I used it on the windscreen. Now I use an Arcol mat, and I do have to wet it to get it to stick on that. _________________ TT Go Essential |
