Pocket GPS World :: View topic - Can't get tomtom 2.07 driver to download to fix MM04 pbm
nigelr
PostPosted: Sat Aug 21, 2004 5:05 pm    Post subject: Can't get tomtom 2.07 driver to download to fix MM04 pbm Reply with quote
Set-up...
Hardware Ipaq HP4150
Tomtom Bluetooth
Latest versions 3.03...
As per previously documented problem… runs fine on TT3 but on MM2004 cannot communicate
Based on earlier tips I have tried dropping the GPS 3.03 and downloaded 2.07 onto PC
However I can’t get this to run.
(I assume I run set-up from the PC as it refuses to run from the IPAQ.)
I get the following error… 8O Crying or Very sad
File d:\nvuk\POCKET.PC.mnu
Line 7: SETUPREQUIRED 4.08
Error: This version of SETUP.EXE is too old to handle the installation of the selected software
Then after pressing enter to clear this I get
Error
Setup instructions not found
Cannot run setup
Please can someone help. MM04 software looks great but bit limied without gps… Idea
Regards
Nigel
PostPosted: Sat Aug 21, 2004 7:43 pm    Post subject: Reply with quote
When the setup is running it actually unpacks the CAB file into a temporary directory. Try copying that cab file directly to your PocketPC and execute it there via the Pocket File Manager
Just to re-emphasize - Do a soft reset between all steps you do. Otherwise the GPS 3.03 driver may still be in memory and prevent installation of 2.07
22.052 (08 May 24)
