candycane Occasional Visitor
Posted: Thu Aug 11, 2011 8:09 pm Post subject: FM Traffic provider database is missing |
Hello o anyone who can help me. I am new to the forum, but am quite frustrated with my Garmin. I purchased a Garmin Nuvi about 2 mos. ago from Walmart. Last month I used it to travel from KY to IA. While traveling through Missouri, "all of a sudden" the maps disappeared and all I was able to use was the actual road direction, but not get any from point to point direction. What showed up on the GPS screen was "The FM Traffic provider database is missing, Go to www.garmin.com/webupdater. I did this, downloaded the updates, but cannot get that to interface between my modem and Garmin. I am using a USB adapter device and making connection with the GPS. We have wireless capability with our internet server, and our computer is Windows XP.
How can I get my GPS to work?? I haven't even been able to use it very long! Thank you for your help. |
Andy_P Pocket GPS Moderator
Posted: Fri Aug 12, 2011 2:51 pm Post subject: |
I'm afraid I'm no Garmin expert, but to me it sounds like you have two separate problems or more likely, whatever the *main* problem is ALSO causing the Nuvi to lose FM reception....
Losing the Traffic FM connection shouldn't lose you the basic mapping functionality.
Is the situation still the same? i.e. no maps showing at all?
Have you tried doing a reset of the Nuvi? I believe that is done by pressing and holding the power button (I'm not sure how long for!). _________________ "Settling in nicely" ;-) |
M8TJT The Other Tired Old Man
Posted: Fri Aug 12, 2011 3:39 pm Post subject: |
Are the maps zoned in the states and presumably Missouri is included in your map set? Just a thought |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Fri Aug 12, 2011 6:49 pm Post subject: |
You don't say which Garmin you have? If you let me know I'll be able to help
Also confirm what mapset you had loaded? |
Posted: Fri Aug 12, 2011 8:25 pm Post subject: Thank you. It is a nuvi 1300. |
Hi--it is a nuvi 1300. The mapset is the latest USA--preloaded when I purchased it.
Thanks!
Posted: Fri Aug 12, 2011 8:29 pm Post subject: |
Andy_P wrote: | I'm afraid I'm no Garmin expert, but to me it sounds like you have two separate problems or more likely, whatever the *main* problem is ALSO causing the Nuvi to lose FM reception....
Have you tried doing a reset of the Nuvi? I believe that is done by pressing and holding the power button (I'm not sure how long for!). |
Thank you. You may be right, because now the GPSis powering off and on, "loading maps", then powering off and on. I can do so manually, as well. It just keeps running through the cycle, and sometimes asks me for my PIN. No screen choice isnow shown past this cycling. Weird, huh? and no---it was not damaged or water logged, either. Yes, I have tried resetting. Sorry--I accidently posted a reply twice....
Posted: Fri Aug 12, 2011 8:40 pm Post subject: |
You may be rigt abot two separate problems. Now it is really acting strangely. It only runs continuously through cycles of powering off and on, but I can also perform this manually. Sometimes tasks me for my PIN, but nver goes to another sceen. I think its a lemon. Aso, I charged it fully overight and it will not hold a charge---I have t pluged in. No damage has occured to this GPS.
Thank you, Andy. |
Posted: Fri Aug 12, 2011 8:51 pm Post subject: |
Sounds like a polite request along the lines of "Please can I have my money back mister" to me. |
Posted: Fri Aug 12, 2011 8:53 pm Post subject: |
How have you tried to reset it? And what happens when you do? |
Posted: Fri Aug 12, 2011 9:15 pm Post subject: |
Okay---I was able to fianally go to the main screen and have option of selecting the Tool/Wrench icon. I was able to do this when I went to the security location I had prevously programmed. Before that I could not even get that screen.
Anyway, when I select Map Info, there is only a blank screen. Then I went to the address icon, it read "no map data available". |
Posted: Fri Aug 12, 2011 9:32 pm Post subject: |
lso, for ome reason, I am not able to interface the GPS wth the computer. I have download the webupdater maps, but cannot get them to relay to the nuvi. Maybe I need another USB cable?? |
Posted: Fri Aug 12, 2011 10:06 pm Post subject: |
Problem with connection could indeed be the cable. You might though want to perform a hard reset, always a good idea when your nuvi doesn't perform as expected. Details are here:
From Garmin's knowledge base
Question:
How do I perform a master reset on my nuvi 200, 205, 465, 500, 600, 700, 705 or 1000 series device?
Answer:
To perform a Master Reset on the nuvi 200, 205, 465, 500, 600, 700, 705, 1100, 1200, 1300, 1400 or 1600 series device:
Note: A master reset will erase all waypoints or Favorites and will restore your unit to the default factory settings. If you would like to back up your Favorites to your computer, you can find instructions to do so here.
• Start with the unit OFF and unplugged from power
• Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
• Continue touching and holding the lower right hand corner of the screen then power the unit ON
• Release the power button when the device powers ON
• You will see a new message: Do you really want to erase all user data?
Remove your finger from the touchscreen when this message displays
• Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
Having done so tap Tools, Settings, Map, Info and see what it says. If you have US maps loaded it will read something like CN NA 2012.10 and there should be a tick mark in the box next to it. If not ticked select it, your maps should now be visible. |
Posted: Sat Aug 13, 2011 3:42 am Post subject: |
Thank you everyone! I have really enjoyed posting with you all and for all words of help and advice. Garmin is sending me a new cable at no cost!! |
