Pocket GPS World :: View topic - 940 no longer recognised as USB device
wildcard
PostPosted: Mon Jul 11, 2011 11:20 am    Post subject: 940 no longer recognised as USB device Reply with quote
Very strange - but my 940 is no longer recognised as a USB device by my PC. The light on the TT turns green for a split second , then red and the PC reports an unrecognised USB device . I have tried other USB ports on the same machine and the TT cradle on another PC - all with the same results. As far as I can tell the TT charges from the cradle in the car .
The only thing I can think of is I've damaged the pins on the cradle when cleaning it - but I can't see any damage.
Any ideas ?
Geoff
dhn
PostPosted: Mon Jul 11, 2011 11:37 am    Post subject: Reply with quote
Have you tried resetting the unit and trying again? Not sure whether your model has a dedicated reset hole or if you need to hold the power button about 10 seconds till the drum sound is heard.
Anita
PostPosted: Mon Jul 11, 2011 11:41 am    Post subject: Reply with quote
You beat me to it! Rolling Eyes
This happens sometimes when I connect my 720 to the PC, and I've always found that a pin in the reset hole sorts it out.
Anita
TomTom VIA 135 - App 12.075
UK map 1125.12264
Samsung Galaxy S21
wildcard
PostPosted: Mon Jul 11, 2011 11:46 am    Post subject: Re: 940 no longer recognised as USB device Reply with quote
Any ideas ?
Geoff
Problem solved ... sorry
I tried removing the micro SD card , shut down , reboot , shut down , insert , place in cradle , reboot. The first time I did this - no change. But the second time - the PC recognised the TT. The light is still red however - does this mean its not charging .
Grrrr................ TT software again .................
wildcard
PostPosted: Mon Jul 11, 2011 11:48 am    Post subject: Re: 940 no longer recognised as USB device Reply with quote
Any ideas ?
Geoff
Problem solved ...
Guys , Thanks for your quick responses - I will keep both methods in reserve for the next time it happens !!!
PostPosted: Fri Jul 15, 2011 2:41 pm    Post subject: Reply with quote
Red DOES mean it's charging....
Green means it's charged.
If you have problems again, try the steps in the THIRD section here.
"Settling in nicely" ;-)
22.043 (17 Apr 24)
