Pocket GPS World :: View topic - in-line car power..
in-line car power..
martin_b
PostPosted: Thu Jul 07, 2011 10:29 am    Post subject: in-line car power.. Reply with quote
Sorry if this is a FAQ i did look!
Im after an inline power supply for my 540.
By in line I mean somthing i can hard wire into the car, so bare wires at one end transformer/regulator in the the middle tom tom connector at the other!
cheers
Martin
molerat
PostPosted: Thu Jul 07, 2011 10:54 am    Post subject: Reply with quote
http://www.vehicle-wiring-products.eu/VWP-onlinestore/switches/photo/041829.jpg
Wire one of these in behind the dash.
Garmin Drive 51LMT-S EU
(TT One V3 512MB + RDS TMC UK&RoI v1005 now retired, dead due to withdrawal of manufacturer support)
matthewj
PostPosted: Thu Jul 07, 2011 4:25 pm    Post subject: Reply with quote
I thought that would be some fancy thing, and not what I'd done, but that is exactly what I used, and it works just fine. Funny how the simple solutions are easiest.
PostPosted: Thu Jul 07, 2011 4:39 pm    Post subject: Reply with quote
Easy to get hold of from your local Maplin store see Here when you plug the charger in to the socket tape it in place with some PVC tape to stop it vibrating out while driving especially if you hiding it under the dash.
If you think you might need more than one socket Maplins also do a number of options with up to four outlets in a single housing to hide behind the dash (which is what I have got) - Mike
martin_b
PostPosted: Thu Jul 07, 2011 5:06 pm    Post subject: Reply with quote
thanks, but i want to get rid of the lighter thing all together, its just too big.
what i may have to do is buy a normal one and dismantle it, remove what i guess will be one IC and a couple of resistors, and remount them
martin_b
PostPosted: Thu Jul 07, 2011 5:07 pm    Post subject: Reply with quote
what i may have to do is buy a normal one and dismantle it, remove what i guess will be one IC and a couple of resistors, and remount them, and get the soldering iron out.
PostPosted: Thu Jul 07, 2011 5:11 pm    Post subject: Reply with quote
Thats making a whole lot of work for very little gain IMHO, sure it can be done but be aware the output cable contains three wires, one of which is a voltage feedback wire, if this breaks it will fry your TomTom, the wires are at best fragile where they attach to the PCB and to be honest they need the strain relief and moulding of the ciggy plug to keep it all intact.
If its buried behind the dash what does it matter about the size/ looks of the plug? - Mike
matthewj
PostPosted: Fri Jul 08, 2011 12:37 pm    Post subject: Reply with quote
Using standard kit also means that they can't dodge blame for anything. If you open and hack their parts, then that's what broke it isn't it?
PostPosted: Fri Jul 15, 2011 2:09 pm    Post subject: Reply with quote
Sorry, late on the scene... But there's always this from TomTom themselves. Does exactly what you want, I think.
Built into the dashboard of your car, this USB charging cable offers a permanent charging solution for your TomTom device and any other 5V USB device.
http://www.tomtom.com/en_gb/products/accessories/chargers-connect-cables/usb-charging-cable/
"Settling in nicely" ;-)
22.044 (24 Apr 24)
