Pocket GPS World :: View topic - Warning sounds for 'Sugested Driving Breaks'
BAZESUE
PostPosted: Fri Jun 17, 2011 5:16 pm    Post subject: Warning sounds for 'Sugested Driving Breaks' Reply with quote
Is it possible to change the warning sound for my TT 950 Live's 'Sugested Driving Breaks'?
PostPosted: Fri Jun 17, 2011 7:52 pm    Post subject: Reply with quote
it's quite possible you can, but I can't think of an easy way to try it out for you!
What I'm guessing is that the driving breaks alerts use one of the standard sound effects.
Now these used to be all coded in a single file called data.chk (which it is possible to edit using some third-party tools) so that could be one way to change it.
However I notice that the standard sounds are also stored in the "sounds" folder on my Go940 and 950 so the system *might* use those now - which would be a lot easier to modify.
My thinking is that if (just for example) the system uses the "notify1.wav" sound for the driving break alerts, then you could just replace the "notify1.wav file with a different sound but still call it "notify1.wav".
My only problem is that I have never used the driving break alerts and so have no idea of the sound used. I just tried switching it on, but there is no demo of it, so I think the only way I would ever get to hear it is by taking a really long journey. Makes testing the theory a bit long-winded!
At least you're in the position of knowing what they sound like now.... Maybe you could have a listen to all the sound effects in the "sounds" folder on the TomTom and see if you can recognise which one is used.
"Settling in nicely" ;-)
PostPosted: Fri Jun 17, 2011 8:04 pm    Post subject: Reply with quote
The alert for the driving breaks isn't selectable it simply plays one of the sound files embeded in the data.chk file, whilst it used to be possible to take this file to bits and rebuild it, I haven't seen any software out to do this with more recent data.chk files (they tend to differ between Navcore releases).
Once the method of using ogg audio files for POI alerts was made available the "old fashioned" method of hacking the data.chk file came to an end and software such as POIExtend became out of date failing to work with software released in the past 3 or 4 years (is it really that long ago).
You could work it out using a hex edit application but its a lot of messing about - Mike
PostPosted: Fri Jun 17, 2011 8:13 pm    Post subject: Reply with quote
Are you sure that it isn't using the files in the sounds folder now?
I don't know as I've not tried experimenting, but all the bings, bongs and cow's moos are there as .wav files and I can't think why they would bother to put them in there if they weren't used for something.
I suppose I could try changing the ringtone. wav and seeing if that changes the sound used when a call comes in.
Only trouble is I'll need to set up a new pairing with my wife's phone as I don't have a phone with BT myself any more!
PostPosted: Fri Jun 17, 2011 8:33 pm    Post subject: Reply with quote
OK... I tried it with the ringtone sound and it DIDN'T use my modified file in the sounds folder. (I know that you can change the ringtone by adding a new sound to the ROOT of the internal memory or SD card, but I was only using it as a test for what we really want to achieve).
The TomTom "Create your own Content" guide, tells you how to change several of the warning and alert sounds, but not the "driving breaks" one.
So, it looks like the only way to change the driving breaks alert is going to be to modify the data.chk file... IF the tools to do it are still available.
Guivre46
PostPosted: Sat Jun 18, 2011 10:20 am    Post subject: Reply with quote
In the warning sounds downloadable from Home, there are spoken text messages. I've used 'Red light camera' and 'mobile speed camera', and 'motorway services' [a very depressing man]. There may be somethng for taking a break, but I can't recall one.
Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom
PostPosted: Sat Jun 18, 2011 12:34 pm    Post subject: Reply with quote
Even if you record your own voice or find the sound you want to use there is no way to select a different sound for the driving breaks, as said earlier the only way is to dissect the data.chk file using a Hex Edit application then work out the contents of it - Mike
BAZESUE
PostPosted: Sat Jun 18, 2011 4:31 pm    Post subject: Reply with quote
Looks like a non starter then. Thanks for all your help.
Baze
PostPosted: Sat Jun 18, 2011 6:58 pm    Post subject: Reply with quote
I hunted down one of the old data.chk editors - (http://www.automated.it/ttg-poipatcher.html and, as expected, it didn't like my recent data.chk file - it threw up a few warnings about not recognising the format and the file it produced still worked but didn't accept the new audio I added.
However, I noticed that the program was based on work done by PGPSW's own CamerAlert guru, Lutz. So it's just possible he might be persuaded to look into the problem once again if you asked really nicely.
Also, I'll suggest to Tomtom that they include the ability to change this sound in future software.
