Pocket GPS World :: View topic - Garmin Proximity Alerts
PostPosted: Fri Apr 29, 2011 6:25 am    Post subject: Reply with quote
I'm reading the files one at a time and loading the data into an array.
I then re-read the file and take note of the Lat and Lon data. I then add and subtract 0.001 from the Lat and Lon position to give me a Min and Max.
I calculated that 0.001 was sufficient by using the Lat and Lon of the variable cameras along the western section of the M25 which are often on the same gantry but on opposite carriageways causing a double warning when one will do in each direction.
I then read through the rest of the file and if any other camera is within the Min and Max for both Lat and Lon then the camera has to be within a very short distance of the one I'm looking at and therefore can be omitted.
On my first run yesterday it worked perfectly for these cameras on the M25 but still gave me warnings for the ones that are on separate gantries.
I'm sure I have a working version now and I'm happy to release it free to anyone interested (including the VB6 source code if anyone wants to improve on it). I would have used VB.NET but I'm not sure how Microsoft's DomDocument4 works with .NET yet for creating the XML files (subsequently renamed to .GPX)
It should still be treated as beta as I've only tested this final version once but I have tested other variants continually during the week.
Satnav:
Car Average MPG :
BigPerk
PostPosted: Fri Apr 29, 2011 9:18 am    Post subject: Reply with quote
Maybe you could license it to Ash10, for a small % of his Paypal donations ... Question Question Razz
(it does look like a very useful utility Smile )
(Navigon 70 Live, Nuvi 360)
PostPosted: Fri Apr 29, 2011 10:45 am    Post subject: Reply with quote
I always preferred CBROM's utility anyway...
This one is more like his. Will be interesting to have a play!
PostPosted: Fri Apr 29, 2011 2:12 pm    Post subject: Reply with quote
Once I get back into the office next Thursday I'll send it over.
ps: I want no dosh for this, it was a labour of love Smile
Satnav:
Car Average MPG :
camerauk
PostPosted: Sun May 08, 2011 8:48 pm    Post subject: Reply with quote
I would love a copy of this please Very Happy
is it windows only or mac compatible does not matter either way
Andy
PostPosted: Mon May 09, 2011 6:33 am    Post subject: Reply with quote
I'm in the process of rewriting it to make use of .NET4 via VS2010. If your happy to have a go with the VB6 version I'll send it over.
It's Windows only and probably won't work with 64bit. Having said that the .Net4 version probably won't either because Microsoft in their infinite wisdom have removed the native controls to display Drive, Directory and File List Boxes so I've had to call on legacy controls that I'm sure aren't 64bit compatible.
Satnav:
Car Average MPG :
PostPosted: Mon May 09, 2011 8:36 am    Post subject: Reply with quote
Why oh why do MS do things like this? Confused
PostPosted: Tue May 10, 2011 6:32 am    Post subject: Reply with quote
It gets worse....
Everything has converted OK except for the UnZip routine and the XML writing bit. They have made it so complicated to produce the required multiple element attributes. So easy using the legacy MSXML4 DomDocument routines.
The GPX file requires an entry like "wpt lon="-2.25405" lat="51.84847"
Easy to produce "wpt lon="-2.25405" but trying to add the second element is proving difficult, even via multiple Googles to find a solution !
I've resorted to using the Win32 Shell for the unzipping so that bit won't work under 64bit Windows I wouldn't think. Shame really.
I can see me calling in the legacy DomDocument for that bit as well.
I'm won't give up though.
Satnav:
Car Average MPG :
PostPosted: Sat May 21, 2011 6:25 am    Post subject: Reply with quote
Latest screendump of my efforts. Now tested on Win 7 32bit and works perfectly Very Happy
I'll upload it Monday. I can't post the download link directly because my company may object. I will post via PM though.
Satnav:
Car Average MPG :
PostPosted: Sun May 22, 2011 2:44 pm    Post subject: Reply with quote
Damn that looks clever, Kremmen.... Where do you go to learn this stuff?
"Settling in nicely" ;-)
PostPosted: Mon May 23, 2011 6:32 am    Post subject: Reply with quote
It's what I do on a daily basis Smile
As far as I can tell it's all working as expected so I'm going to upload it to the company server. I have one PM to send with the link.
It should work on all versions of Windows except possibly for the programmatic unzipping of the database which may be restricted to 32bit machines. I'm sure someone will tell me. For this reason it's possible to manually unzip the file and the program will acknowledge that it's now found CSV files which can be converted to GPX with user set requirements.
Satnav:
Car Average MPG :
m-a-r-k
PostPosted: Wed May 25, 2011 7:23 pm    Post subject: Reply with quote
How can we get to play with this wonderful program? Very Happy
Mark B
Garmin nüvi 350
SW V6.20, GPS SW V3.00
City Navigator Europe NT 2018.10
PostPosted: Thu May 26, 2011 6:33 am    Post subject: Reply with quote
PM sent with download link Smile
Satnav:
Car Average MPG :
tailz
PostPosted: Thu May 26, 2011 7:03 am    Post subject: Reply with quote
Hi Kremmen,
If your program is ready for use/trials, I would be grateful to have a play.
Tony
PostPosted: Thu May 26, 2011 9:05 am    Post subject: Reply with quote
Done Smile
Satnav:
Car Average MPG :
Page 2 of 3
22.052 (08 May 24)
