Pocket GPS World :: View topic - another map update problem... TT750 LIVE.
DaveNN
PostPosted: Wed Mar 02, 2011 8:35 pm    Post subject: another map update problem... TT750 LIVE. Reply with quote
As noted elsewhere, the latest maps for the TT750 Live are too big for the device.
I stuck a 4 gig card in & selected this as the destination drive.
After about a hour, I was hit with a message that the memory was not big enough & transfer to the TT had failed.
OK...so I then stick a 16gig card in backed up the TT to it (all works well).
However, when I now try to download the full maps I am informed that the memory on my device is not large enough & am given the option to download the map regions.
Home recognises the card (I 'selected it')..so I'm flummoxed why it won't allow the download.
Any advice would be appreciated.
NB, I haven't removed the software from the TT- could this be the problem?
Jaguar XF R Sport AWD
Onboard nav with live stuff, weather, news and stuff.
NextBase Duo DashCam
Running Cameralert via Samsung S7 Edge
PostPosted: Wed Mar 02, 2011 9:45 pm    Post subject: Reply with quote
Copy everything from the internal device memory to your computer then on to the MicroSD card, a 4GB card is more than adequate. You can then remove the files from the device internal memory, insert the car and switch the unit on, let it boot up before switching off and removing the memory card.
Next pop the card in to a card reader (not the TomTom) and use Home to update the map on the memory card, this avoids the mistake Home often makes by trying to put the map in to the wrong location even when you have told it what you wanted - Mike
DaveNN
PostPosted: Wed Mar 02, 2011 10:34 pm    Post subject: Reply with quote
Thanks, as ever Mike.
Will try that now...
KR
DaveNN
PostPosted: Thu Mar 03, 2011 1:10 am    Post subject: Reply with quote
I still don't understand why Home seems to do this, but only to some people.
I've installed quite a few maps to SD card now and not once has Home tried to put it onto the internal memory as well/instead.
DaveNN
PostPosted: Thu Mar 03, 2011 9:32 am    Post subject: Reply with quote
Paul,
It got worse...Once I'd started to install to the sd card, I got an error about 10 mins in (file missing..don't know why..but have created a new download folder to try again) AND to add insult to injury all my favourites have wandered off..even though I did a complete backup.
(I hope that this new map is worth it..in the long run)
HELP PLEASE Very Happy
jadonx
PostPosted: Sat Mar 05, 2011 2:46 pm    Post subject: Reply with quote
From what I remember with my 750, I just moved (not copied) map over in explorer. From then on tomtom home updates map every time ok.
This uses internal and external memory with my 2gb Europe map on the 4gb card.
It doesn't even matter which drive letter you choose when home starts.
also on this thread-
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=82589&postdays=0&postorder=asc&start=30
