Pocket GPS World :: View topic - GPS won't lock on Samsung Galaxy Portal
chrisf_1962
PostPosted: Tue Jan 25, 2011 9:44 am    Post subject: Reply with quote
Thanks for the info, I must admit I'd never heard of A-GPS before. I'll have to do some more research and in the meantime hope that Lutz can weave some magic and provide a fix for us poor unfortunates.
Chris
PostPosted: Tue Jan 25, 2011 10:06 am    Post subject: Reply with quote
A-GPS is 'Assisted GPS' i.e. it doesn't just use the satellite signals to get the position. The initial location is estimated using things such as mobile phone cell triangulation, wifi IP location and, sometimes, using tables of data to work out roughly where the satellites should be in order to get their signal faster.
MJLONGLEY
PostPosted: Tue Jan 25, 2011 10:43 am    Post subject: Samsung Galaxy Portal - Same problem for me too. Reply with quote
Hi Guys,
You had totally lost me until the last post 'shed a little light'
Have I got this correct -
Although all the 'smart' devices in question have GPS receivers and the theoretical ability to establish the device location from that alone, some software (Google Maps for instance) first seeks to establish an approximate (is that coarse?) location via the network before 'pin-pointing' the exact location via satellite, whereas Cameralert is attempting to bypass the first step and go directly to satellite location?
If I am correct I still do not understand why the location by satellite alone is failing?
My Mio dedicated SatNav with no network usually picks up 5-8 satellites in my conservatory and the Cameralert on the Dell also works OK there.
Google Maps on both Dell & Samsung works fine there also.
Both the Dell & Samsung are on the '3' network.
Mike Longley.
PostPosted: Tue Jan 25, 2011 10:57 am    Post subject: Re: Samsung Galaxy Portal - Same problem for me too. Reply with quote
Partly correct, CamerAlert is not 'attempting' to bypass coarse location data, it is ignoring it completely as it is not accurate enough to be of any use.
This appears to identify a bug on some devices that will only deliver GPS data on top of coarse location. If you ignore coarse location you don't get GPS. This only affects some platforms it would seem.
So GPS is not failing, but is is being blocked on the handset because we choose not to accept coarse location data as it is not suitable for our purposes.
Darren Griffin - Editor
MJLONGLEY
PostPosted: Tue Jan 25, 2011 11:05 am    Post subject: Samsung Galaxy Portal - Same problem for me too. Reply with quote
Thanks.
So -
software that accepts initial 'coarse' location is allowed access to GPS location
BUT
software that ignores initial 'coarse' location is denied access to GPS location, and therefore any form of location establishment
on this particular device.
Correct?
Mike Longley.
PostPosted: Tue Jan 25, 2011 11:08 am    Post subject: Re: Samsung Galaxy Portal - Same problem for me too. Reply with quote
MJLONGLEY wrote:
So -
BUT
Correct?
As far as we can figure it, yes. But we're still looking into the finer details. Lots of discussion of this issue on other Android forums.
Once we can be certain of the cause we can look at what options are open to us to circumvent it.
Geologist
PostPosted: Mon Feb 07, 2011 2:54 pm    Post subject: Re: Samsung Galaxy Portal - Same problem for me too. Reply with quote
Have you managed to resolve this issue yet as I am having the same problem (No GPS Fix with Samsung Galaxy Portal while Google maps etc works correctly).
Regards
PostPosted: Mon Feb 07, 2011 3:11 pm    Post subject: Reply with quote
the latest app version (on the Android market) has a switch to enable network location fix. That _should_ solve the problem. Please try it out.
PostPosted: Mon Feb 07, 2011 3:13 pm    Post subject: Reply with quote
hint: it's under 'Advanced settings'
Geologist
PostPosted: Mon Feb 07, 2011 4:56 pm    Post subject: Reply with quote
Thanks for the quick reply. I've updated and will have a look when I get outside
MJLONGLEY
PostPosted: Mon Feb 07, 2011 5:21 pm    Post subject: GPS won't lock on Samsung Galaxy Portal Reply with quote
Thanks guys,
I haven't had time to try it 'on the move' in the car yet, but it is certainly working at home now whereas previously it was not!
Thanks for the hint on where to find the setting,without that I doubt that I would have located it.
Geologist
PostPosted: Mon Feb 07, 2011 7:58 pm    Post subject: Reply with quote
Thanks - seemed to have worked for me to (only tested on my bike though! Very Happy )
MJLONGLEY
PostPosted: Wed Feb 09, 2011 1:05 pm    Post subject: GPS won't lock on Samsung Galaxy Portal Reply with quote
Hi again Guys,
Sorry - I spoke too soon - it is not working!
I spent time yesterday and today out in the car with the Samsung Galaxy Portal and the Dell Streak.
The Dell Streak works perfectly but the Samsung fails to lock on and therefore the icon stays Red. It tracks my progress on the map OK and shows the yellow camera location warning icons OK (which previously it did not do) but the speed indicator remains at 0 and there are no warnings whatsoever.
Occasionally the icon briefly turns Blue, usually when stationary at a junction or traffic lights (also in the house which is why I initially thought all was well) but the moment the car begins to move it goes Red again.
I tried setting the new Network switch on the Dell Streak but it had no adverse effect, it continued to behave perfectly.
Is there anything else that you want me to try to attempt to 'pin down' the problem?
Mike Longley.
chrisf_1962
PostPosted: Thu Feb 10, 2011 9:07 pm    Post subject: Reply with quote
Same for me I'm afraid. I downloaded the update, found the switch and turned it on after a few seconds the map corrected itself and the gps indicator went blue. Unfortunately after a couple of seconds more it went red and I've never managed to get a gps lock since.
Chris
Geologist
PostPosted: Sat Feb 12, 2011 3:09 pm    Post subject: Reply with quote
Been out today in the car for the first time and unfortunately it's the same for me.
Page 2 of 4
21.014 (25 Jan 23)
