Pocket GPS World :: View topic - Operate my GO error "calling method on NPObject!"
Post new topic   Reply to topic    Pocket GPS World Forum Index -> MyTomTom / TomTom HOME Desktop
Stewart166
PostPosted: Sun Sep 12, 2010 1:18 am    Post subject: Operate my GO error "calling method on NPObject!" Reply with quote
Hello all. I haven't been on here for a while (the Tomtom has been working!). I now have a problem and I apologise if it has been dealt with elsewhere on the forum - I did a search and couldn't find anything relevant.
A week ago I was offered an update of Tomtom Home to 2.7.6.2056 (not sure what it was before but it was the previous version). I was also offered a map update from Australia 845.2661 to 855.2884. I then tried to use "operate my GO" from Home and got the message "Error calling method on NPObject!". Here is the full error:
Code:
ERROR: Error: Error calling method on NPObject!
in chrome://tthome/content/ui/subtask/emulator/emulatorPage.js:232
Stack:
0. function startup_navigator("M62357B05413","8-351-9982-1.dll","22","Latin-1","H:")   unknown
1. function ()   chrome://tthome/content/ui/subtask/emulator/emulatorPage.js:232
                                                dataFolder);
2. function ([object XML])   chrome://tthome/content/ui/subtask/emulator/emulatorPage.js:148
                        this.initEmulator();
3. function ([object XML])   chrome://tthome/content/logic/util.js:79
                return func.apply(obj, arguments);
4. function ()   chrome://tthome/content/logic/comm.js:442
                    this.successCallback(this.resultXML);
5. function (true)   chrome://tthome/content/logic/comm.js:430
            this._doneCallbacks();
6. function ([object ProgressEvent])   chrome://tthome/content/logic/comm.js:277
            this.request.onload = function() { me._done(true); }
Time: Sun, 12 Sep 2010 00:10:34 GMT
While my immediate assumption was that it was caused by the updates, I am now less sure. I had not used "Operate my GO" for a week or so previously. Indeed, I've tried reverting to an earlier version of Home (2.6) and the previous map, and got the same.
All this is on a laptop running XP, which I wish to continue using as the machine on which I manage the Tomtom. I do have access to another machine running Win 7 which has not previously had Home installed on it. I installed Home on that and found that "Operate my GO" worked normally on that machine.
I logged a support job with Tomtom and they suggested a couple of fairly generic processes (deleting the Tomtom directory in "My Documents", and when that did not work, a much lengthier one involving deleting and reloading the Tomtom application on the device, which did not work either). Now they are just saying "something wrong with your computer, not our problem".
Searching the web for references to this error show that it is not limited to Tomtom - it seems to come up in the context of Java or Javascript (that might be evident from the error message but I am not an expert).
I would be very grateful for any suggestions.
edit: I should have said that I have downloaded and installed the current version of Java.
dhn
PostPosted: Sun Sep 12, 2010 1:27 am    Post subject: Reply with quote
Try this.....
Download and install Revo Uninstaller from here. Get the freeware version.
Now completely uninstall Home.
Next, get a fresh copy of Home from here:
http://www.tomtom.com/services/service.php?id=16
Try to connect now and see if things are better.
(note: make sure you know the email address/pw associated with your unit as REvo Uninstaller will remove the stored info)
Stewart166
PostPosted: Sun Sep 12, 2010 2:57 am    Post subject: Reply with quote
Thanks very much dhn! That has done the trick.
PostPosted: Sun Sep 12, 2010 4:41 am    Post subject: Reply with quote
Moved to "Home" section (and I've edited the title a bit to clarify the topic).
Stewart166
PostPosted: Sun Sep 12, 2010 9:13 am    Post subject: Reply with quote
Thanks - it wasn't obviously a HOME problem when I first posted.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> MyTomTom / TomTom HOME Desktop All times are GMT + 1 Hour
22.051 (01 May 24)
