Joined: Apr 04, 2006 Posts: 295 Location: South East Northumberland, UK
Posted: Sun Sep 05, 2010 5:53 pm Post subject:
trooper wrote:
Greenglide wrote:
By appending the contents of one of the .rex files given earlier to this thread the numbers come out correctly without losing anything such as the SMS abbreviations.
This is the content I am currently using - you can copy and paste the contents of the box - highlight all of the text in the box, control+c to copy and then ctrl+v to paste it wherever you want it.
Good luck! _________________ TomTom Go 540 - V9.058, Map GB & Ireland 860.3101
TomTom Go 520T, V8.351, TTS V7, Map GB & Ireland 855.2884
Nokia 5800 with Google Maps & OVI Maps
Google Nexus One with Google Maps & NDrive
Posted: Sun Sep 05, 2010 8:56 pm Post subject:
Just had a try with the .rex file and found a few errors where "one seven" was read as "seventeen" etc when there was a digit before it.
I have inserted \Nx parameters to correct this.
Two consecutive zeros are still pronounced with a slight hesitation espacially with number like 1200, 1002 doesnt seem as bad.
I think the "oh, oh" (used to stop it running the two words into one) needs replacing by phonetics or maybe "oh owe", "owe owe" or "owe oh". I may try that during the week.
The advantage of this technique is that it is only used for GB English so it shouldnt mess up any other languages (hopefully) _________________ TomTom Go 540 - V9.058, Map GB & Ireland 860.3101
Tried this latest fix on my 930 running WC&E maps but sadly didn't work.
Keep up the good work and hopefully you'll get a fix that works on all versions.
Posted: Mon Sep 06, 2010 1:10 pm Post subject:
So what doesnt work? Is it punctuation being read out (comma, semi-colon etc)?
Were you using the small number of rules or MARVIN2003's version with the smaller number?
The WC&E maps do give problems and I don't think anyone has cracked the issue yet. Logically the contents of the EnglishGbTT.rex file and the trace facility "should" enable this to be fixed. I dont have the WC&E map _________________ TomTom Go 540 - V9.058, Map GB & Ireland 860.3101
Replaced the .rex file with the full version and extra code appended to the end. It did not make the slightest change to how it pronounced the road numbers. Stiill e.g. 'two hundred and three' or 'three thousand and thirty seven'.
Would it matter where the extra code was placed?
Joined: Nov 27, 2005 Posts: 132 Location: Stroud, Gloucestershire
Posted: Tue Sep 07, 2010 10:16 am Post subject:
First of all, these rules will only work with Loquendo 7.
If you add the new rules to the end of the EnglishGbTT.rex file, you should not need any of the other files, as this file gets read by default, as long as you are using a UK English voice.
Note: This file also includes a rule that replaces 0 0 with nil nil which you may need to remove for some road numbers.
Putting the code in this file does seem to stop the 'semi-colon' and 'comma' problems, although I have only given it a quick test.
It still seems to ignore the rules for B roads though on the W&CE map.
I am using Loquendo V7. I'm not sure what the 'semi-colon' and 'comma' problems are. However it does not read the road numbers, on the short test, I did any differently.
If the original .rex file is where it gets the numbers information from then surely where the new code is placed in the file becomes important - or have I got that wrong?
Posted: Tue Sep 07, 2010 3:04 pm Post subject:
Pocketgps wrote:
I have just tried MARViN2003's files on my Go530 using UK & ROI v8.55 maps.
It reads out the A roads okay as well as the M roads, but I get no B roads, just says the road name and no B or numbers. Is this correct
eg
'A1234 london road' are okay
'M6' okay
'B1234 london road' - says 'london road' only - no B or numbers read out.
Is this with the extra lines appended to the EnglishGbTT.rex file leaving all the previous lines present?
I have the larger set on my previous posting in the EnglishGbTT.rex file on my 540 with version 855 maps and it works fine on motorways, A roads and B roads.
I will try it on my 520 with version 855 maps tonight to check if it works on that (it has Loquendo version 7 installed).
I am using the cphoneme.dat file in the map - renaming it did not give any improvement to pronunciation that I noticed. Could this be the problem? Otherwise, you havent got MARVIN2003s other files installed as well have you? _________________ TomTom Go 540 - V9.058, Map GB & Ireland 860.3101
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Tue Sep 07, 2010 6:15 pm Post subject:
Greenglide wrote:
1. Is this with the extra lines appended to the EnglishGbTT.rex file leaving all the previous lines present?
2. I will try it on my 520 with version 855 maps tonight to check if it works on that (it has Loquendo version 7 installed).
3. I am using the cphoneme.dat file in the map - renaming it did not give any improvement to pronunciation that I noticed. Could this be the problem?
4. Otherwise, you havent got MARVIN2003s other files installed as well have you?
1. No, will try that
2. Loquendo version 7 is installed
4. I installed the 5 files that are in the zip file - is this wrong then ?
Posted: Tue Sep 07, 2010 8:01 pm Post subject:
You either place MARVIN2003s files in the \loquendo\data folder or you append the additional lines (either the 10 or so lines to read "0" as "oh" rather than zero or the smaller set in MARVIN2003s zip file). _________________ TomTom Go 540 - V9.058, Map GB & Ireland 860.3101
Posted: Tue Sep 07, 2010 8:55 pm Post subject:
Appended the set of rules that read "oh" rather than zero (the larger one) on my 520T with 855 maps and it works fine.
It works with B roads and correctly identifies double 0 despite the condition earlier in the existing file.
I can see no reason why it should work on a 520 with a version of Loquendo v7 from an x30 device and a 540 both with UK & Ireland map 855 but not work on a x30 device.
Might be worth checking installation and if desperate using the trace facilty but that is excedingly verbose!
I think I am happy to live with the solution so far though. _________________ TomTom Go 540 - V9.058, Map GB & Ireland 860.3101
With a bit of trepidation I've removed the five files from the DATA folder and edited the EnglishGbTT.rex file by adding the larger set of rules posted by Greenglide.
I've done a desktop demo and the punctuation errors appear to be gone, and the B4009 close by was pronounced as "B four oh oh nine" although a bit jittery.
I'm back to driving up the "High Strit" instead of street though, although this may not be due to the recent changes, it's just that maybe I haven't done something when upgrading to the latest map! _________________ Mike
