Pocket GPS World :: View topic - Go 910 - change the size/placement of MPH speed warning
greenwood03
PostPosted: Thu Sep 02, 2010 11:27 am    Post subject: Go 910 - change the size/placement of MPH speed warning Reply with quote
longshot i guess. Wondered if anyone is aware of any hacks/mods that allows the speed reading ( bottom right ) to be moved or increased in size? In my car the speedo is nowhere near eyesight/line, whilst the TT is perfectly positioned, however there are times when its not quite possible to see the readings ( normally its a bit light for that size of info ), would be ideal if there was a way to increase the size of that info......
anyone know of anything that can be done?
thx Mark
dhn
PostPosted: Thu Sep 02, 2010 11:45 am    Post subject: Reply with quote
The size of the fonts used for the various pieces of information in the status bar are hard coded into the application.
Have you tried having the status bar placed vertically?
greenwood03
PostPosted: Thu Sep 02, 2010 11:51 am    Post subject: Reply with quote
NO i hadnt tried that option, just found it and changed it - will give that a try. If i select less option ( arrival time etc etc ) does that make the remaining info any larger? ( i'm assuming not )
dhn
PostPosted: Thu Sep 02, 2010 12:19 pm    Post subject: Reply with quote
Don't think so......just more empty space.......
PostPosted: Thu Sep 02, 2010 7:22 pm    Post subject: Reply with quote
Turn off all the other items on the status bar in preferences and you should see the area available for the speedo increases along with the font size - Mike
dhn
PostPosted: Thu Sep 02, 2010 8:45 pm    Post subject: Reply with quote
You're right, Mike.
I'm wrong. Again. Embarassed Embarassed
PostPosted: Thu Sep 02, 2010 8:55 pm    Post subject: Reply with quote
David, you 're right on the newer models... The way the status bar is laid out now, the font size doesn't change if you remove items and if you try to add too many it just tells you that you can't
dhn
PostPosted: Thu Sep 02, 2010 9:36 pm    Post subject: Reply with quote
Thanks, Andy........ I owe you: Cheers!
greenwood03
PostPosted: Fri Sep 03, 2010 8:41 am    Post subject: Reply with quote
cheers Guys, appreciate your help and interest! will see how i go with that when i'm out and about tomorrow.
