DefenderBLACK Lifetime Member
Joined: 23/06/2003 17:45:35 Posts: 103 Location: United Kingdom
Posted: Wed May 26, 2010 7:10 am Post subject: Amigo - Poi's? |
Help, where do i download my poi's to on amigo? on my igo it used to be content/userdata/poi but cant find this path in amigo? only one i can see is amigo/content/poi but this contains a uk.poi file can i put them their and are they in the same kml format as i need for igo?
Thank you
Paul |
linknet Frequent Visitor
Posted: Wed May 26, 2010 8:57 am Post subject: Re: Amigo - Poi's? |
DefenderBLACK wrote: | Help, where do i download my poi's to on amigo? on my igo it used to be content/userdata/poi but cant find this path in amigo? only one i can see is amigo/content/poi but this contains a uk.poi file can i put them their and are they in the same kml format as i need for igo?
Thank you
Paul |
If content/userdata/poi doesn't exist then just create it, same kml format as for igo should work.
linknet |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Wed May 26, 2010 1:33 pm Post subject: |
If you still have the iGO8 userdata/poi folder, copy it over to your Amigo content folder, you can then add more as and when required. _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
Posted: Wed May 26, 2010 1:41 pm Post subject: |
Lost_Property wrote: | If you still have the iGO8 userdata/poi folder, copy it over to your Amigo content folder, you can then add more as and when required. |
Be careful here since not all versions of Amigo create similar index files, make sure you only copy the actual kml files.
linknet |
Posted: Wed May 26, 2010 5:00 pm Post subject: |
Quote: | make sure you only copy the actual kml files. |
Yes of course, I should have added, delete the .kix and .kns files. _________________ Formerly known as Lost_Property
Posted: Wed May 26, 2010 8:34 pm Post subject: |
many thanks |
