Pocket GPS World :: View topic - Griffin Power Jolt - effect on sound output
austhorpe
PostPosted: Fri Apr 02, 2010 5:21 pm    Post subject: Griffin Power Jolt - effect on sound output Reply with quote
Hi all,
Bit of a weird one this, was using the TT app earlier with a Griffin Power Jolt plugged in to keep it charged.
I then noticed no voice instructions, no music from the iPod, I just put it down to a crash.
When i got out of the car the sound was fine with the TT app and everything else!
I started the iPod going, plugged the power jolt in and then the music stops, as does the TT voice instructions!
Anyone come across this? why does it do it? and can it be stopped?
Many thanks
PostPosted: Fri Apr 02, 2010 5:32 pm    Post subject: Reply with quote
It's an Apple thing, if it detects ext power has been removed it pauses music etc. Same happens to my Kensington LiquidAux Carkit.
No way of stopping it as far as I know. The same happens if you have headphones in an iPod/iPhone/Touch. Unplug them and the audio is paused.
austhorpe
PostPosted: Fri Apr 02, 2010 5:35 pm    Post subject: Reply with quote
Maybe I did not explain properly the voice instructions dont work when the power jolt is plugged in! When its out it works fine!
PostPosted: Fri Apr 02, 2010 5:48 pm    Post subject: Reply with quote
What if you connect power and THEN start the app?
austhorpe
PostPosted: Fri Apr 02, 2010 5:55 pm    Post subject: Reply with quote
No makes no bloody difference!
Plug it in and it comes up accessory not supported do you want to turn airplane mode on?
It acts just like when I dock it with my Bose sound dock. Weird.
Used my dads cheapo charger from eBay and it's bloody fine!
PostPosted: Fri Apr 02, 2010 6:37 pm    Post subject: Reply with quote
What device are you using it with? I've just checked and it's only supported on v1 Touch and iPod's. Not suitable for any iPhone variant.
austhorpe
PostPosted: Fri Apr 02, 2010 6:41 pm    Post subject: Reply with quote
well that's that then! I am using a 3g s!
I was sure someone on here said they used a power jolt.
PostPosted: Fri Apr 02, 2010 10:53 pm    Post subject: Reply with quote
There are different versions of PowerJolt, I use this which IS supported whereas this isn't.
Montala
PostPosted: Tue Apr 06, 2010 6:54 pm    Post subject: Reply with quote
Thanks Darren.
For those of us in the UK, it looks as if the supported version can be purchased from Amazon for £11.15
It does specifically mention iPhone, so hopefully it will be OK, as I have just ordered one!
PostPosted: Tue Apr 06, 2010 7:35 pm    Post subject: Reply with quote
I can assure you it does, it's what I use Smile
Montala
PostPosted: Tue Apr 06, 2010 7:57 pm    Post subject: Reply with quote
Thanks again Darren... I can't ask for a better recommendation than that now, can I! Wink
Actually, I have just noticed that the title of this thread says Garmin Power Jolt, rather than Griffin... perhaps you could 'edit' that! Smile
gajet
PostPosted: Fri Apr 09, 2010 10:07 pm    Post subject: Reply with quote
It's not the Power Jolt with the auxillary socket to connect to your stereo is it?
If it is you would have to manually redirect the audio output from "Dock Connector" to "speaker" using the iPod app.
22.044 (24 Apr 24)
