Newsletter
Pocket GPS World :: View topic - Out of memory problems?
Retty
PostPosted: Wed Mar 10, 2010 3:59 pm    Post subject: Out of memory problems? Reply with quote
Could someone else confirm that the following legitimate postcode gives an out of memory error (CE 4.2 PDA device) using iGO8:
LU6 2LF
Border_Collie
PostPosted: Wed Mar 10, 2010 6:29 pm    Post subject: Reply with quote
Unnamed road near Dunstable. On the map it points to a gap in a road which looks like it was once one maybe.
PostPosted: Wed Mar 10, 2010 7:21 pm    Post subject: Reply with quote
Gives the OOM error on mine too. LU6 2LG is OK
CE4.2 PNA device
Retty
PostPosted: Fri Mar 12, 2010 3:24 pm    Post subject: Reply with quote
CE4.2 PNA device
It seems to be software version specific (not a problem on early 8.3.2) and it does not depend on size of poi or speedcam files; when it does happen it's rural postcodes with no house numbers that trigger it; some do work though. The problem appears when exiting the house number entry screen (pressing "done" without an entry) and not on routing.
Manually adding the postcode entry to the "history" file (editing the file or using a file from an earlier working version) and selecting it from there instead of inputting the postcode normally works fine. It's hardly a workaround but it shows something. Not sure what.
It may suggest that the problem is less to do with hardware memory limits and more to do the buggy code.
Retty
PostPosted: Fri Mar 12, 2010 9:12 pm    Post subject: Reply with quote
CE4.2 PNA device
Sorry, I meant "CE 4.2 PNA" device too (not PDA) ;-)
johalareewi
PostPosted: Mon Oct 17, 2011 6:08 pm    Post subject: Reply with quote
I have had the out pf memory error too with rural postcodes and iGo 8 but it has been OK if I put in the town and street.
19.121 (01 Dec 21)
Terms & Privacy
