Pocket GPS World :: View topic - TM 5 ResNavigatorEU error
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Telmap User Group
dliu24
PostPosted: Mon Jan 25, 2010 7:12 pm    Post subject: TM 5 ResNavigatorEU error Reply with quote
After installing TM 5, I get this error every time I try to run TM5:
Error starting ResNavigatorEU: Module 'ResNavigatorEU-15' must be signed with the RIM Runtime Code Signing Key (RRT).
Any ideas? Thanks.
SyBorg
PostPosted: Tue Jan 26, 2010 3:55 pm    Post subject: Reply with quote
What device? Blackberry? If so BES or BIS?
ecarrot
PostPosted: Tue Jan 26, 2010 5:00 pm    Post subject: Reply with quote
I get the same error. BB 8900 on BIS.
dliu24
PostPosted: Tue Jan 26, 2010 7:17 pm    Post subject: Reply with quote
My bad, skipped my mind to post what I am using. Just like the last post, I am also using a Blackberry Curve 8900 on BIS. I rebooted, uninstalled, and reinstalled. Same error message each time.
ecarrot
PostPosted: Mon Feb 01, 2010 3:50 am    Post subject: Reply with quote
I have been left without Telmap for a week now. Any solution to this problem?
SyBorg
PostPosted: Mon Feb 01, 2010 10:03 am    Post subject: Reply with quote
No real solution that I can think of. The only thing I would do, given the time and inclination, would be to remove the install and try the BES one. No reason to think it would work but what have you got to lose?
ecarrot
PostPosted: Mon Feb 01, 2010 5:02 pm    Post subject: Reply with quote
I installed the BES one and it works.
Thanks.
SyBorg
PostPosted: Mon Feb 01, 2010 6:00 pm    Post subject: Reply with quote
Good stuff Very Happy
dliu24
PostPosted: Sat Feb 06, 2010 5:53 am    Post subject: BES did not work for me Reply with quote
I tried BES (and BIS again), neither worked for me. Man...
Vibsak
PostPosted: Mon Feb 08, 2010 11:36 pm    Post subject: ResNavigatorEU: Module 'ResNavigatorEU-15' must be signed Reply with quote
I'm encountering the same error. Curve8900 on AT&T. Tried both BIS and BES versions. Set all the app permissions to "Allow".
Vibsak
PostPosted: Sun Feb 21, 2010 4:22 pm    Post subject: Error starting ResNavigatorEU: Module 'ResNavigatorEU-14' mu Reply with quote
Can someone help me. I downloaded this app several weeks back, has not been able to use it even once. I keep getting this error message
Error starting ResNavigatorEU: Module 'ResNavigatorEU-14' must be signed with the RIM Runtime Code Signing Key (RRT).
I've also provided this report in the feedback survey.
My phone is Curve 8900 on ATT. Also, after this error, the phone becomes very sluggish, when the app is deleted the phone becomes speedy again.
Not sure what's happening. I know I must use the BIS version (but I trued both BES and BIS). I've tried other GPS software with voice guided, they seem to work except this one.
TUGAdmin
PostPosted: Wed Feb 24, 2010 4:02 pm    Post subject: Errors downloading Telmap5 Reply with quote
Hi Vibsak,
A new version is available from the usual place.
Please try downloading that.
We have also seen download errors in the following circumstances:
- Using the device WAP browser - make sure you are using the BB Internet browser
- Poor network connection - this sometimes causes a network timeout - a file only gets partially downloaded and is therefore corrupted.
Hope that helps.
TUGAdmin
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Telmap User Group All times are GMT + 1 Hour
