Pocket GPS World :: View topic - Clip-on and Stowaway.
nuts
PostPosted: Sun Jul 11, 2004 8:19 pm    Post subject: Clip-on and Stowaway. Reply with quote
I am stumped.
I have a Stowaway XT keyboard and TomTom (with a Clip-on).
For some reason these two seem to interfere as TomTom can't find satelites on my Clip-on (BT manager can find the clip-on) since I installed the stowawy.
Anyone had a similar problem?
And even more important: a solution?
TC
PostPosted: Fri Jul 16, 2004 11:38 pm    Post subject: Reply with quote
Nuts,
May be someone could help you if you gave a bit more information. Also the description you give is a bit confusing, at least to me.
I'm not sure how you conclude that the Stowaway XT keyboard interferes with TomTom. For instance TomTom won't find any satellites if you can't get a Bluetooth connection to the Clip-on in the first place.
I don't know anything about the Stowaway, but I see there's a bluetooth version out, I know you state that you have the XT, but are you sure its not the Bluetooth version? I know often you can only connect to one Bluetooth device at a time. Plus they could be trying to share the same ports.
Does the set-up work when the keyboard isn't connected? Have you tried to re-pair the Clip-on after/while using the Stowaway?
Sorry if you checked all these things but if you can gave a bit more explanation someone might just be able to help
Ipaq 2210
Fortuna Clip-on [Xtrac V2]
Tom Tom Navigator 3
Memory Map
nuts
PostPosted: Sat Jul 17, 2004 10:42 pm    Post subject: Reply with quote
Thanks for your reply.
I have already fixed the problem.
For some reason drivers of a Stowaway XT keyboard and drivers of a GPS-device on one PPC cause a conflict in ports.
However Stowaway has acknowledged this problem and has issued a driver that can be disabled so you can turn of the Stowaway driver when using a GPS-device.
