Pocket GPS World :: View topic - TT3 upgrade??
TT3 upgrade??
overtime
PostPosted: Fri Jul 09, 2004 12:04 pm    Post subject: TT3 upgrade?? Reply with quote
In our company we have several people who have just upgraded to 3.03.
Without exception they all have the same problem with the new software. This is what happens. They set a destination and provided they stick rigidly to the instructions, than all is OK. However on one route the instruction tells them to turn right when leaving an office. The problem is that you cannot turn right as it is a one way street. Now if you turn left then the software deos not 're-route' and no further audible instructions are received. I have tried this at other places and the same thing happens.
So we have now reverted to the original version and all is OK.
Has anyone else experienced this?
Torchy
PostPosted: Fri Jul 09, 2004 3:00 pm    Post subject: Reply with quote
Strange that you should mention this because I have just spoken to a friend and he has experienced the same problem. I have noticed that this also happens when using the postcode facility. After a journey I have to do a soft reset, clear the journey details and then continue, If I go off route then I lose the voice and the display just shows my location.
I will try your idea and revert to the original software.
Morris
PostPosted: Fri Jul 09, 2004 4:29 pm    Post subject: Reply with quote
I have not experianced this with one way streets. However at other times when I 'stray' from Tomtoms chosen route it usually recalculates very quickly.
Morris
Grzzzzzz Thumbs Up
Torchy
PostPosted: Fri Jul 09, 2004 11:32 pm    Post subject: Reply with quote
The one way street was only an example. What I tried to get across was that when you deviate from the original route, the program does not set up a 're-route'
Talkingbollox
PostPosted: Fri Jul 09, 2004 11:47 pm    Post subject: Reply with quote
Stating the obvious - have you set "automatic re-planning" under the advance tab in properties?
Torchy
PostPosted: Sat Jul 10, 2004 6:41 am    Post subject: Reply with quote
If you mean 'automatic re-planning' then the answer is 'YES'
Morris
PostPosted: Sat Jul 10, 2004 6:23 pm    Post subject: Reply with quote
I;ve tried to 'break it' in the way you have described, but it works perfectly, quickly recalculating the route.
Morris
Grzzzzzz Thumbs Up
alix776
PostPosted: Sat Jul 10, 2004 6:29 pm    Post subject: Reply with quote
in have to deiate from the tt route quite a lot just due to the size and weight of what im driving and ive no poblems at all with rerouting using 3.04
device Lumia 950 xl
gokhart
PostPosted: Sat Jul 10, 2004 6:57 pm    Post subject: Reply with quote
I have tested and have no problems re-routing. Continoulsy went off following different routes. Even took the M6 toll, so it showed me wandering off the mapped roads, until it recalculated to a road nearby (continusly as I follwed the M6 toll), then re calculated when I rejoined the normal motorway.
usually happens quite quick, I used the strict routing.
IPAQ 2210 Rom 1.00 CF 512MB
TT3 / TTBT & Fortuna Clip-On
overtime
PostPosted: Sun Jul 11, 2004 8:51 am    Post subject: Reply with quote
Obviously something is wrong then but all I can say is all of the staff have the same problem except 1. The systems were installed individually and were done by the folks themselves. Strange! Rolling Eyes
Sierra662
PostPosted: Sun Jul 11, 2004 11:35 am    Post subject: Reply with quote
Hi...
Why don't you get the guy that installed the working system to re-install the rest.??
Steve.
22.052 (08 May 24)
