Pocket GPS World :: View topic - Tomtom Go 720 Replacement Battery
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
PostPosted: Sat Oct 10, 2009 8:34 pm    Post subject: Reply with quote
I'll bet they either replace the innards as a whole or an entire replacement unit.
Then they send it back to you with out of date software and a two year old map!
PostPosted: Sat Oct 10, 2009 9:09 pm    Post subject: Reply with quote
Article from the Launch and my first impressions of the TomTom Start are here.
Editor, PocketGPSWorld.com
Calomax
PostPosted: Sat Oct 10, 2009 10:13 pm    Post subject: Reply with quote
I'm reluctant to correct an editor, but have you posted in the right thread Mike?
TT Go Essential
PostPosted: Sat Oct 10, 2009 10:31 pm    Post subject: Reply with quote
Laughing
(what you need is a mod. to sort it out for you! Wink )
PostPosted: Sun Oct 11, 2009 9:42 am    Post subject: Reply with quote
Smile I am always open to correction, and after a long day often make mistakes...
bat9985
PostPosted: Wed Oct 14, 2009 4:24 am    Post subject: Reply with quote
My wife and I have 2 TomTom Go720's, both have batteries with waning capacity. I've been following this thread, ordered the tools and I'm about to order the batteries.
I was wondering if anyone considered using a solvent on the battery adhesive? In the US we have a couple of products I've used on adhesives, Goo Gone and Sticker Lifter, both available at the local hardware store.
Both have worked well to remove adhesive on a variety of surfaces, including plastics and the the paint on a car body, without damaging hte surfaces.
Thanks for providing this forum and assembling the info.
Bryan
mightyyid
PostPosted: Thu Oct 15, 2009 6:29 am    Post subject: Reply with quote
Bryan
Bryan
The key issue is that in order to gain access to the solvents holding the battery in place, you have to lift the battery up to get this access and in doing so, you then actually begin to 'peel' the battery away from the PCB, thus doing what you set out to do without the aid of solvents.
It could be that this will help if sprayed on and left, in the same way that WD40 loosens bolts etc, but with the ease of over-spray, I'd be tempted to try the suck it and see - slowly - approach and gently prise the battery up.
Interesting you will do two of them. One will be very easy, the other bloody difficult. The easy one will be the first one.
Law of sods, averages, and tomtom....
EricWB
PostPosted: Thu Oct 15, 2009 8:49 am    Post subject: Reply with quote
The weird thing is that even if at the last moment you decide to do the last one first, and the first one last, it wont make any difference, the last one will still be difficult, its called sods law.
Brad99
PostPosted: Fri Oct 16, 2009 11:04 pm    Post subject: Reply with quote
MrT wrote:
Cameras also only use power momentarily when taking a picture, GPS devices run continously processing information.
Digital cameras use a lot of power all the time they're switched on, especially if the display is on. Their sleep modes are very efficient though.
AliOnHols
PostPosted: Sat Oct 17, 2009 6:02 am    Post subject: Reply with quote
Andy_P wrote:
Laughing
Seek and Ye shall find. Congratulations Very Happy
Garmin Nuvi 2599
SatMap Active 10 & 20.
PostPosted: Sat Oct 17, 2009 2:03 pm    Post subject: Reply with quote
Thanks! It was just going through that evening....
garcor
Location: Nova Scotia & Florida in Winter Go 920 App 8.351 Maps NA 850 & C/W EU 830
PostPosted: Fri Oct 23, 2009 1:01 pm    Post subject: Reply with quote
I have had my 920 for 20 mts now and not used a lot but has sat on home cradle most of the time.
My battery is now dead; it simply will not take a charge. Not even for 5 minutes.
When connected to the computer it will connect to TT home but it will not stay on if I chose the option to not to connect to computer but still leaveing it on the cradle.
It will still work fine when plugged in the car charger or when I have it on the (optional) home charger.
I am thinking that I might be willing to try and change the battery but I wonder if I might be better to buy an external rechargeable power source.
Has anyone had any luck using a rechargeable external power source and if so how long will it run and if you have a link to where they can be bought.
Gary
MarkMarkB
PostPosted: Fri Oct 23, 2009 3:58 pm    Post subject: Reply with quote
Oddly enough I have been having similar thoughts and have recently bought a rechargeable device and an external power source that uses 4 AA cells. The rechargeable device has two Sony Li-Po cells of 1350mAh each, so should provide twice the life of the original battery. The TomTom mounts in the rechargeable device and the whole thing mounts on the original bracket. The combined weight tends to cause the thing to drop over time. The widget powered by the 4 AA cells is cheap and effective and useful if you are away from any charging source. I got them off Ebay, try searching for
Battery Extender Charger for TomTom Go 930 930T
and
Portable Battery Pack Mount Holder For Tomtom 920 930T
stuart
PostPosted: Fri Oct 23, 2009 5:11 pm    Post subject: Alternative to replacing the battery Reply with quote
There is also this option which might be alot easier..
http://www.pdamods.com/proddetail.asp?prod=111A1TT720EXTBATPACK
garcor
PostPosted: Fri Oct 23, 2009 8:31 pm    Post subject: Re: Alternative to replacing the battery Reply with quote
Mark had some good suggestions but for my situation I think your suggestion for this battery pack would do the trick if it were a good as they say, especially if it would give you ten hours of use.
Have you tried this unit or is there anyone that has tried this as an external power source.
Gary
Page 5 of 9
21.093 (20 Sep 23)
Terms & Privacy
