Pocket GPS World :: View topic - TT720 boots, but only gets as far as start up screen then !
peasemore
PostPosted: Thu Sep 24, 2009 5:55 pm    Post subject: TT720 boots, but only gets as far as start up screen then ! Reply with quote
Haven't used my 720T for about 4 weeks, but have had on charge on PC and in car earlier most of day but it won't display for more than few seconds when powered in car; with TT Home it stays on, & I can use Operate My Go, but in car, even when powered up won't work properly.
Is this the dreaded battey grief?
Shouldn't it work anyway if it's on car power with green led on.
Is it worth doing re install, or will that be pointless.
Comments valued.
Gel
Lifetime Member Thames Valley, Berkshire, UK
Mazda CX-5 built in SatNav- not sure if TT or not. Garmin NUVI in reserve.
PostPosted: Thu Sep 24, 2009 6:14 pm    Post subject: Reply with quote
First off try the reset switch on the base of the device, secondly format the device and re-install everything - Mike
peasemore
PostPosted: Thu Sep 24, 2009 6:37 pm    Post subject: Reset Reply with quote
Thanks Mike; have dome multiple resets today but no joy on the problemo!
Will re format and advise.
Gel
peasemore
PostPosted: Thu Sep 24, 2009 6:56 pm    Post subject: ttn file Reply with quote
Mike, I formatted and used clear flash tool but after this I noticed there's small 15kb file called "TTN".
What's that for incidentally?
Is it needed??
Was trying to find the thread here re formatting & reloading the HDD from a Windows backup, but can't find at mo.
I don't use an SD card currently.
Copying across back up I did in Windows earlier today, with view all files switched on.
I wonder if latest TT's have better battery life; mine was bought Apr 2008, and has had an easy life; as others have noted batty replacement should be far easier, as is known consumable/TT revenue stream.
Gel
AliOnHols
PostPosted: Thu Sep 24, 2009 10:53 pm    Post subject: Reply with quote
peasemore, the ttn file is used by some 3rd party applications. It has been known to cause problems on Start Up if it is configured wrongly. Suggest you remove it from your TT and store it safely somewhere on your PC and re-boot the TT without it as a test. Running TT without the ttn file may make any 3rd party apps you have unusable though.
Garmin Nuvi 2599
SatMap Active 10 & 20.
