Pocket GPS World :: View topic - go 730 quick fix
go 730 quick fix
crypticx
PostPosted: Thu Aug 20, 2009 8:18 pm    Post subject: go 730 quick fix Reply with quote
had this one for last 3 month but the last 5 weeks when i update with tomtom home get the mapshare ok .but no quick fix. had a problem with the maps kept coming up no maps found.had made aback up.so decided to format it.no probs .but since then no quick fix.hope somebody can help with this.thanks in advance
PostPosted: Thu Aug 20, 2009 8:45 pm    Post subject: Reply with quote
Try this:
1. Find the "ephem" folder on the TomTom itself and delete the contents (leaving the folder empty).
2. On your PC, go to where Home stores it's downloads (normally C:\Documents and Settings\username\My Documents\TomTom\HOME\Downloads\complete on an XP machine) and find the "ephemeris" folder. Again, delete all the contents, leaving the folder empty.
That should kick-start the GPSQuickFix downloads again, next time you connect to Home.
crypticx
PostPosted: Fri Aug 21, 2009 4:39 pm    Post subject: Reply with quote
will give it a go m8 just got home. another thing is when i connect tomtom then go to start my computer i have drie c and drive d but my tomtom is now showing up as removeable drie f .instead of romtom
PostPosted: Fri Aug 21, 2009 4:55 pm    Post subject: Reply with quote
Don't worry about the drive not showing up as named "TomTom" and the actual letter it uses will change from time to time if you add/ remove other USB memory devices to the PC such as digital cameras etc - Mike
crypticx
PostPosted: Fri Aug 21, 2009 6:59 pm    Post subject: Reply with quote
right first of all thanks andy and mike.have deleted the content of the ephem on my comp.but cant find it on my tomtom-unless its hidden
PostPosted: Fri Aug 21, 2009 7:19 pm    Post subject: Reply with quote
Has your device not got an "ephem" folder in the root of the device? - It should be in there - Mike
crypticx
PostPosted: Fri Aug 21, 2009 7:38 pm    Post subject: Reply with quote
alright mike dont know what you mean about root.been through every folder on my tomtom cant find ephem anywere.thanks
crypticx
PostPosted: Fri Aug 21, 2009 7:54 pm    Post subject: Reply with quote
should i just make a "ephem" folder and put it on my tomtom
PostPosted: Fri Aug 21, 2009 7:55 pm    Post subject: Reply with quote
When you connect the device to the PC and use Windows Explorer your device appears as a seperate drive letter, when you expand/ open this by clicking it you are in the "Root" directory, its the highest level available to you before you start to drill in to the individual folders - Mike
crypticx
PostPosted: Fri Aug 21, 2009 8:16 pm    Post subject: Reply with quote
thanks mike but no "ephem" folder to be found. bit stuck now
AndyVaughan
PostPosted: Fri Aug 21, 2009 8:17 pm    Post subject: Reply with quote
If you don't have the ephem folder that is why QGPSFix isn't being offered.
With your device connected to your PC just open the drive letter that is your TT with Explorer and create a folder called ephem
Now HOME should offer you the QGPSFix
TT made a mess of a Navcore release not long ago and missed out the ephem folder from the build .......
crypticx
PostPosted: Fri Aug 21, 2009 8:49 pm    Post subject: Reply with quote
well have tried that and still no quick fix in the ephem file on my comp in ephem there are 3 files ee meta tlv packedephem erris.ee ee meta are they the ones to delete.i have dragged the on to my desktop.so the folder is now empty.just incase i have the wrong folder.i can always put them back thanks
crypticx
PostPosted: Sat Aug 22, 2009 1:35 pm    Post subject: Reply with quote
ok sorted it went to a back up and put the folder of there into tomtom and quick fix works thanks for all your help
22.052 (08 May 24)
