Pocket GPS World :: View topic - Unable to apply updates to TT3.01 - please help!
Paulthenewbie
PostPosted: Thu Jun 24, 2004 6:24 pm    Post subject: Unable to apply updates to TT3.01 - please help! Reply with quote
Hi all,
Just installed TT 3.01 (409) for the first time. Everything works great. Have tried to install updates but when activesync links to my 2210 I just get the Add/Remove programs screen and a list of programmes I've already installed - it will not allow me to upgrade. Activesync works fine with everything else. Any ideas where I'm going wrong? Sad
Paulthenewbie
PostPosted: Thu Jun 24, 2004 7:05 pm    Post subject: Problem solved - zip file works, exe file doesn't! Reply with quote
- zip file on TT site works, exe file doesn't!
oddsock
PostPosted: Thu Jun 24, 2004 7:57 pm    Post subject: Reply with quote
I used the .exe file and every thing went OK I think!! how do I check if I actually have 3.03 on my pda ?
dave
ttrevor
PostPosted: Thu Jun 24, 2004 8:38 pm    Post subject: Reply with quote
Start TT ,go to maps ,file, about, you should see TomTom Navigator 3.03
cheers trevor
Iphone x 64gb IOS 11.3.1 / IPhone 6 Plus 32gb IOS 12 beta /Volkswagen Scirocco R 280 bhp /Suzuki Vitara swb vvt+ /Suzuki Jimny special/running Apple Mac Mini / Apple air/ iPhone x /6 plus navigation / Apple car-play
oddsock
PostPosted: Thu Jun 24, 2004 11:09 pm    Post subject: Reply with quote
3.03(427) so the .exe worked ok on the 2210!
thanks
dave
SteveW
PostPosted: Fri Jun 25, 2004 1:19 am    Post subject: Reply with quote
Just loaded it on my new 2210 also via the 'exe'- works fine
Steve
mrwhitelabel
PostPosted: Mon Jun 28, 2004 12:25 am    Post subject: Reply with quote
i cant get it to work from the exe or the zip file
getting these errors :
any suggestions ? Question
PostPosted: Mon Jun 28, 2004 8:56 am    Post subject: Reply with quote
It sounds like the version you have downloaded has corrupted. Re-download the exe file but make sure you disable any download managers before doing so.
mrwhitelabel
PostPosted: Tue Jun 29, 2004 12:55 am    Post subject: Reply with quote
thanks ive disabled d'load managers and it installs ok to where it says select language and install tom tom
then it gives error box saying cant connect to device (it is connected to active sync) and then another box saying it has generated errors and windows is closing it ?
never had any other problems installing
im using a mio digiwalker pda with pocket pc 2003
thanks for all the help so far
xda
PostPosted: Tue Jun 29, 2004 8:03 am    Post subject: Reply with quote
Instead of trying to put the files on the Desktop/
Open "My Computer" and create a new folder called TomTom in the Route of C:\ and put the EXE in the newly created TomTom directory, the run the EXE file from there.
Graham.
Map: Europe V910.4892
Nokia 925 Windows 8
mrwhitelabel
PostPosted: Wed Jun 30, 2004 1:06 am    Post subject: Reply with quote
tried this and ive disabled d'load managers and it installs ok to where it says select language and install tom tom
any other suggestions ? ive diablred firewall (although it didnt need it to install tomtom 1st time) only thing thats changed on my system since then is afdding google tool bar with pop up blocker could this be a problem ?
SPY
PostPosted: Wed Jun 30, 2004 10:07 pm    Post subject: Reply with quote
I also could not use the EXE file, it would install the original 3.01.
Zip file worked first time.
mrwhitelabel
PostPosted: Sun Jul 04, 2004 8:05 pm    Post subject: Reply with quote
tried doing from the zip file got the same error cant conect to device
so i tried again this time it starts showing the transfer screen
then freezes after about 10 mins
so i try yet again and it says "cxant connect to device" and then "unknown device architecture"
is this an issue with the Mio ?
any one elkse with one sucessefully upgraded
or any one suggest a reason as to what could be going wrong Twisted Evil
PostPosted: Sun Jul 04, 2004 8:14 pm    Post subject: Reply with quote
Have you tried soft resetting the Mitac?
mrwhitelabel
PostPosted: Sun Jul 04, 2004 8:47 pm    Post subject: Reply with quote
trying that now
