Paulthenewbie Occasional Visitor
Posted: Thu Jun 24, 2004 6:24 pm Post subject: Unable to apply updates to TT3.01 - please help! |
Hi all,
Just installed TT 3.01 (409) for the first time. Everything works great. Have tried to install updates but when activesync links to my 2210 I just get the Add/Remove programs screen and a list of programmes I've already installed - it will not allow me to upgrade. Activesync works fine with everything else. Any ideas where I'm going wrong? |
Posted: Thu Jun 24, 2004 7:05 pm Post subject: Problem solved - zip file works, exe file doesn't! |
- zip file on TT site works, exe file doesn't! |
oddsock Pocket GPS Verifier
Joined: May 01, 2004 Posts: 706 Location: Monmouthshire
Posted: Thu Jun 24, 2004 7:57 pm Post subject: |
I used the .exe file and every thing went OK I think!! how do I check if I actually have 3.03 on my pda ?
dave |
ttrevor Lifetime Member
Joined: Dec 04, 2003 Posts: 540 Location: Sleaford Lincolnshire UK
Posted: Thu Jun 24, 2004 8:38 pm Post subject: |
Start TT ,go to maps ,file, about, you should see TomTom Navigator 3.03
cheers trevor _________________ Iphone x 64gb IOS 11.3.1 / IPhone 6 Plus 32gb IOS 12 beta /Volkswagen Scirocco R 280 bhp /Suzuki Vitara swb vvt+ /Suzuki Jimny special/running Apple Mac Mini / Apple air/ iPhone x /6 plus navigation / Apple car-play |
Posted: Thu Jun 24, 2004 11:09 pm Post subject: |
3.03(427) so the .exe worked ok on the 2210!
thanks
dave |
SteveW Frequent Visitor
Joined: 21/05/2003 22:54:59 Posts: 516 Location: Leicestershire UK
Posted: Fri Jun 25, 2004 1:19 am Post subject: |
Just loaded it on my new 2210 also via the 'exe'- works fine
Steve |
mrwhitelabel Occasional Visitor
Posted: Mon Jun 28, 2004 12:25 am Post subject: |
i cant get it to work from the exe or the zip file
getting these errors :
any suggestions ? |
Dave Frequent Visitor
Posted: Mon Jun 28, 2004 8:56 am Post subject: |
It sounds like the version you have downloaded has corrupted. Re-download the exe file but make sure you disable any download managers before doing so. |
Posted: Tue Jun 29, 2004 12:55 am Post subject: |
Dave wrote: | It sounds like the version you have downloaded has corrupted. Re-download the exe file but make sure you disable any download managers before doing so. |
thanks ive disabled d'load managers and it installs ok to where it says select language and install tom tom
then it gives error box saying cant connect to device (it is connected to active sync) and then another box saying it has generated errors and windows is closing it ?
never had any other problems installing
im using a mio digiwalker pda with pocket pc 2003
thanks for all the help so far |
xda Lifetime Member
Posted: Tue Jun 29, 2004 8:03 am Post subject: |
mrwhitelabel wrote: | i cant get it to work from the exe or the zip file
any suggestions ? |
Instead of trying to put the files on the Desktop/
Open "My Computer" and create a new folder called TomTom in the Route of C:\ and put the EXE in the newly created TomTom directory, the run the EXE file from there. _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
Posted: Wed Jun 30, 2004 1:06 am Post subject: |
xda wrote: | mrwhitelabel wrote: | i cant get it to work from the exe or the zip file
any suggestions ? |
Open "My Computer" and create a new folder called TomTom in the Route of C:\ and put the EXE in the newly created TomTom directory, the run the EXE file from there. |
tried this and ive disabled d'load managers and it installs ok to where it says select language and install tom tom
any other suggestions ? ive diablred firewall (although it didnt need it to install tomtom 1st time) only thing thats changed on my system since then is afdding google tool bar with pop up blocker could this be a problem ? |
SPY Occasional Visitor
Joined: May 15, 2004 Posts: 30 Location: Hertfordshire
Posted: Wed Jun 30, 2004 10:07 pm Post subject: |
I also could not use the EXE file, it would install the original 3.01.
Zip file worked first time. |
Posted: Sun Jul 04, 2004 8:05 pm Post subject: |
SPY wrote: | I also could not use the EXE file, it would install the original 3.01.
tried doing from the zip file got the same error cant conect to device
so i tried again this time it starts showing the transfer screen
then freezes after about 10 mins
so i try yet again and it says "cxant connect to device" and then "unknown device architecture"
is this an issue with the Mio ?
any one elkse with one sucessefully upgraded
or any one suggest a reason as to what could be going wrong |
Darren Frequent Visitor
Posted: Sun Jul 04, 2004 8:14 pm Post subject: |
Have you tried soft resetting the Mitac? _________________ Darren Griffin |
Posted: Sun Jul 04, 2004 8:47 pm Post subject: |
Darren wrote: | Have you tried soft resetting the Mitac? |
trying that now |
