Pocket GPS World :: View topic - ReverseItn by roussillat
chelsky
PostPosted: Tue Jun 23, 2009 4:05 pm    Post subject: ReverseItn by roussillat Reply with quote
Does anybody know if this is needed now that T.Y.R.E has a reverse itn. button on the main program? Thanks
chelsky
JockTamsonsBairn
PostPosted: Fri Jun 26, 2009 6:41 pm    Post subject: Re: ReverseItn by roussillat Reply with quote
chelsky
If you could run TYRE on your TT, then you would have no need of another utility to do the same thing! However, if you just want a utility to quickly reverse the stops on an ITN, ON YOUR TT, then ReverseItn seems ideal. However, if you always plan your ITNs using TYRE, then you could make a reversed copy and take it with you. I suppose it depends how often you need to reverse an ITN and know in advance. The advantage of using TYRE to reverse it would be that you can then move the reversed stops to the correct side of a motorway/dual carriageway (unless TYRE does that automatically?).
Jock
chelsky
PostPosted: Fri Jun 26, 2009 6:45 pm    Post subject: Reply with quote
Hi Jock. No tyre doesn't do that automaticlly as I have found to my cost!!! I will stick with two .itn's, one there and one back. Thank you.
chelsky
