Pocket GPS World :: View topic - TMC on Navigon 8100
TMC on Navigon 8100
gwentvillan
PostPosted: Tue Mar 24, 2009 8:10 pm    Post subject: TMC on Navigon 8100 Reply with quote
Does this work
a) with just the unit
b) will it only work with the mount
c) or will it only work with the mount and the cable plugged in ?
Is it better to specify an FM station as mine hardly ever finds TMC info otherwise
Andrew
BigPerk
PostPosted: Tue Mar 31, 2009 11:35 pm    Post subject: Reply with quote
Not too helpful but at least I'm First
I've only used it on (c) so can't say about the other options. But I've had no real problems with reception as such so don't think FM is the point. More likely it's the often reported c**p (er - bad) coverage in the UK (depending on where you are).
(Navigon 70 Live, Nuvi 360)
gwentvillan
PostPosted: Mon May 11, 2009 10:41 pm    Post subject: Reply with quote
anyone else got an answer on this ?
gwentvillan
PostPosted: Tue May 26, 2009 10:09 pm    Post subject: Reply with quote
the tmc aerial is part of the car charger for the 8100
jonandmarkuk
PostPosted: Wed May 27, 2009 10:06 am    Post subject: Reply with quote
I normally get reasonable TMC reception, but it does depend on the FM signal. Generally found the reception to be better than the string.
I have found a TMC Y splitter on a German site which allows connection to the car's FM aerial then a USB port plugs into the holder with a thru connector for the power.
I'll track down the link and post it later tonight if anyone is interested.
Navigon 8450 LIVE
jonandmarkuk
PostPosted: Wed May 27, 2009 4:41 pm    Post subject: Reply with quote
Link as promised
http://www.ge-tectronic.de/onlineshop/product_info.php/info/p216_TMC-Y-Adapter-with-miniUSB-Connector--for-Navigon-Device-.html
Navigon 8450 LIVE
