Pocket GPS World :: View topic - sdhc memory card
sdhc memory card
jiffter
PostPosted: Fri May 01, 2009 7:18 pm    Post subject: sdhc memory card Reply with quote
I have recently bought a Garmin 865t sat/nav.I was told a sdhc micro card would not work on it but i've been using a 4gb card with mp3's on it without any problem.I've noticed you can get a 16gb card but i'm wondering if it will work with the Garmin. Reluctant to buy the card until i know it does.
many thanks in advance.
PostPosted: Fri May 01, 2009 7:37 pm    Post subject: Reply with quote
4GB cards can still be found in both SD and SDHC styles, remove the card from the device and check for any markings on it saying it is either SD or SDHC, if its the latter you can probably go all the way to a 32GB card - If the card you have fitted to the device is SD only then tread carefully unless anyone else can confirm this will work in the device - Mike
jiffter
PostPosted: Fri May 01, 2009 8:07 pm    Post subject: sdhc memory card Reply with quote
Thanks for that,the card is definately an sdhc memory card so i presume i can use a 16 or 32gb version on it.
