chelsky Regular Visitor
Posted: Mon Apr 20, 2009 5:07 pm Post subject: tt720+sd or sdhc |
Excuse my ignorance but is the card slot on a 720 sd or sdhc? If it is sd then I need to buy one with an adapter for sdhc. How do you rate Transcend cards, or any recomendations of others. I read Mikes post as to class 6 being fastest. Thanks
chelsky |
253 Lifetime Member
Joined: Mar 05, 2007 Posts: 1058 Location: The green bit between the M40, M4 and M25.
Posted: Mon Apr 20, 2009 5:35 pm Post subject: |
I'm using a Sandisc 8gb SDHC in my 720. No complaints (yet) _________________ Triumph Tbird 1700. And now a Bonnie T100. |
Posted: Mon Apr 20, 2009 6:01 pm Post subject: |
Hi 253. So are you saying it is an sdhc slot or do you need an adapter |
spikeywelsh Regular Visitor
Posted: Mon Apr 20, 2009 7:03 pm Post subject: |
sd or sdhc are the same size card, the only diffrence is how the data is saved to the card.
i have a sdhc card and use it with out any problems |
Posted: Mon Apr 20, 2009 7:32 pm Post subject: |
Thanks for that spikeywelsh, problem solved |
Posted: Mon Apr 20, 2009 8:06 pm Post subject: |
As long as you have Navcore 8,300 or later installed your 720 will support SDHC up to and including 32GB capacity - Mike |
JockTamsonsBairn Lifetime Member
Posted: Tue Apr 21, 2009 11:51 pm Post subject: |
mikealder wrote: | As long as you have Navcore 8,300 or later installed your 720 will support SDHC up to and including 32GB capacity - Mike | Mike, Is that the case for all TTs with 8.3 or above? _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
Posted: Tue Apr 21, 2009 11:59 pm Post subject: |
It applies to all x20/ x30 and x40 devices, these units running 8,3xx or newer can support up to and including 32GB capacity cards, bear in mind the x40 needs the MicroSD or Transflash style card but even these are available in 32GB capacity these days at a rather costly purchase price though!
I am not too sure about the One/ XL range or Go-x10 devices as I think they can only use the standard SD cards - Mike |
Andy_P Pocket GPS Moderator
Posted: Wed Apr 22, 2009 10:36 am Post subject: |
As far as I know, that is correct.
You *might* manage to get an SDHC card to work in a One or XL, but you are pushing your luck. |
Nairbh Occasional Visitor
Posted: Sun Apr 26, 2009 9:50 pm Post subject: SDHC card in 720 |
I'm using a 16GB Transcend SDHC card in my 720 for last two months, no problems at all. Got most of my MP3 collection installed and hundreds of pics, which have been reduced in size prior to copying onto card. |
