Pocket GPS World :: View topic - tt720+sd or sdhc
tt720+sd or sdhc
chelsky
PostPosted: Mon Apr 20, 2009 5:07 pm    Post subject: tt720+sd or sdhc Reply with quote
Excuse my ignorance but is the card slot on a 720 sd or sdhc? If it is sd then I need to buy one with an adapter for sdhc. How do you rate Transcend cards, or any recomendations of others. I read Mikes post as to class 6 being fastest. Thanks
chelsky
253
PostPosted: Mon Apr 20, 2009 5:35 pm    Post subject: Reply with quote
I'm using a Sandisc 8gb SDHC in my 720. No complaints (yet) Very Happy
chelsky
PostPosted: Mon Apr 20, 2009 6:01 pm    Post subject: Reply with quote
Hi 253. So are you saying it is an sdhc slot or do you need an adapter
spikeywelsh
PostPosted: Mon Apr 20, 2009 7:03 pm    Post subject: Reply with quote
sd or sdhc are the same size card, the only diffrence is how the data is saved to the card.
i have a sdhc card and use it with out any problems
chelsky
PostPosted: Mon Apr 20, 2009 7:32 pm    Post subject: Reply with quote
Thanks for that spikeywelsh, problem solved Very Happy
PostPosted: Mon Apr 20, 2009 8:06 pm    Post subject: Reply with quote
As long as you have Navcore 8,300 or later installed your 720 will support SDHC up to and including 32GB capacity - Mike
JockTamsonsBairn
PostPosted: Tue Apr 21, 2009 11:51 pm    Post subject: Reply with quote
Mike, Is that the case for all TTs with 8.3 or above?
Jock
PostPosted: Tue Apr 21, 2009 11:59 pm    Post subject: Reply with quote
It applies to all x20/ x30 and x40 devices, these units running 8,3xx or newer can support up to and including 32GB capacity cards, bear in mind the x40 needs the MicroSD or Transflash style card but even these are available in 32GB capacity these days at a rather costly purchase price though!
I am not too sure about the One/ XL range or Go-x10 devices as I think they can only use the standard SD cards - Mike
PostPosted: Wed Apr 22, 2009 10:36 am    Post subject: Reply with quote
As far as I know, that is correct.
You *might* manage to get an SDHC card to work in a One or XL, but you are pushing your luck.
Nairbh
PostPosted: Sun Apr 26, 2009 9:50 pm    Post subject: SDHC card in 720 Reply with quote
I'm using a 16GB Transcend SDHC card in my 720 for last two months, no problems at all. Got most of my MP3 collection installed and hundreds of pics, which have been reduced in size prior to copying onto card.
