Pocket GPS World :: View topic - Tripmaster is now working with NavCore 8
Goto page Previous  1, 2, 3, 4, 5  Next
Graeme2812
PostPosted: Sat Mar 28, 2009 3:38 pm    Post subject: Reply with quote
This is a great program. I tried installing it previously on my 730T but it did not run. Tried again (v2.0) on my 540 and it worked first time with no problems.
I have just a couple of queries if I may,
My current setup has the logging activated automatically when I start tripmaster. Is there a way to have the logging deactivated on programme startup? Do i simply need to set parameter "Autologging No" to achieve this?
Is is also possible to increase the frequency and accuracy at which the loggin occurs? I'd like to log some routes and have them as accurate as possible. For this I'm using *.gpx format.
Here's a copy of my config...
[Log files parameters]
trackperiod 60
trackdistance 2
trackcourse 30
trackformat gpx
tracksaving new
logfilename tracklog.gpx
autologging yes
records long
[Display Parameter]
language english.lng
units english
colorscheme auto
compass both
coordinates degminsec
gmtoffset 1
geoidfix no 48
snapping no
processperiod 500
bootstart no
displayaltitude yes 5
inclinometer 1
speedlimit 150
speedalarm both
speedinterval 33 44 55 66 77
alarmfilename /mnt/sdcard/tripmaster/speed_alarm.ogg
alarmperiod no 10
[Colors parameters]
topforegroundcolors 0,0,0 255,192,64 204,204,204
bottomforegroundcolors 255,255,255 255,192,64 204,204,204
topbackgroundcolors 255,255,255 0,0,0
bottombackgroundcolors 0,0,128 0,0,128
linescolors 204,204,204 255,192,64
labelcolors 255,0,0 255,255,0
Graeme Bennett
Go 540 LIVE
App. 9.510.1234792.1 (2039,04/04/2013)
United Kingdom & ROI v945.6174
roussillat
PostPosted: Sun Mar 29, 2009 8:17 pm    Post subject: Reply with quote
Can you send me an email at roussillat (at] gmail.com so that I can send you a debug version ?
Have you read, at least, the instruction manual ? Everything you're asking for is detailed in it...
Graeme2812
PostPosted: Sun Mar 29, 2009 11:18 pm    Post subject: Reply with quote
I did, it wasn't until just after I sent the post i realised how to do it along with a few other config edits. Appoligies Embarassed
(e-mail sent)
Graeme Bennett
Go 540 LIVE
roussillat
PostPosted: Wed Apr 01, 2009 8:33 pm    Post subject: Tripmaster v2.2 is available Reply with quote
Hello,
Tripmaster v2.2 is available for download.
http://www.webazar.org/tomtom/tripmaster.php?lang=uk
This version provides a third setup screen and allows you to put back customized backgrounds.
s3dbw
PostPosted: Wed Apr 01, 2009 9:21 pm    Post subject: Reply with quote
Would still appreciate a quick way to reset the average speed if this was possible?
regards
roussillat
PostPosted: Wed Apr 01, 2009 9:59 pm    Post subject: Reply with quote
Which average speed ? both ?
s3dbw
PostPosted: Wed Apr 01, 2009 10:38 pm    Post subject: Reply with quote
Hi Roussillat,
Thanks for getting back, to be honest whatever is the easiest for you to do or both. It was just to have the ability to do a quick reset in the same way as you can for the trip reset. It would be absolutely perfect then!
best regards
Zebb
PostPosted: Thu Apr 02, 2009 10:20 am    Post subject: Reply with quote
If you are still updating Tripmaster, would it be possible to add a few characters near the numbers for Maximum speed (MAX), Total Average Speed (TAS), Moving average Speed (MAS) and so on. Just so we know what the numbers stand for. Thanks.
You must live on a cliff edge to get a -84% reading. ;)
stuart
PostPosted: Thu Apr 02, 2009 11:13 am    Post subject: Tripmaster 2.2 Reply with quote
Thanks again Roussillat,
This version is working even better on my old TTG 500. It's a little slow when I touch the screen but fine.Got the altitude showing on my maps every 2 seconds which is interesting on my trips up north to Scotland.
podge3
PostPosted: Thu Apr 02, 2009 7:24 pm    Post subject: Reply with quote
Doesn't work on my Tomtom running 7.832 Navcore - no Tripmaster icon appears.
I might try adding a menu item manually but then I'll think I'll lose "help" and "mapshare" etc.
roussillat
PostPosted: Thu Apr 02, 2009 10:09 pm    Post subject: Reply with quote
Unfortunately, I won't add those characters that would made the screen difficult to read. If you use regularly Tripmaster, you'll be able to know which information is where.
I'm not leaving on a cliff, just having a poor GPS reception in my dining room ;-)
JockTamsonsBairn
PostPosted: Thu Apr 09, 2009 1:48 pm    Post subject: Reply with quote
I've set this up on my 940, to record some tracks over the weekend. I'll let you know how I get on.
One question:
When I "background" Tripmaster, by tapping the lower left area, the tap seems to carry through to the TT application, so, since the lower left area coincides with the TT volume control, I immediately get "You have reached your destination" shouted at me. The volume I need in the car is considerably higher than the volume that I need in the lounge! Shocked Laughing
Is this "normal", i.e. does it happen to everyone?
Jock
s3dbw
PostPosted: Thu Apr 09, 2009 2:14 pm    Post subject: Reply with quote
Nope, you are not alone, I get the same thing each time as well.
JockTamsonsBairn
PostPosted: Thu Apr 09, 2009 2:18 pm    Post subject: Reply with quote
Thanks, at least I know that it's not something I've done!
Jock
sheepdip1
PostPosted: Fri Apr 10, 2009 8:27 pm    Post subject: Reply with quote
Just found out that Tripmaster has been updated. I have installed it on my One XL however I also suffer from the tripmaster icon being missing from the main menu. As far as I can see you should have 4 pages on the main menu with Tripmaster installed but I have only 3.
I have installed the V2.2 downloaded from the webazar website so should have the most up to date version and am using the default tomtom menu on version V8.010.
Any ideas?
Page 3 of 5
