Pocket GPS World :: View topic - Favourites from a 720 to a 940
tez
PostPosted: Thu Jan 15, 2009 6:04 pm    Post subject: Favourites from a 720 to a 940 Reply with quote
Hi all
Can I transfer all my Favourites from my go720 to my go940 live as when I copied and pasted the MapSettings.cfg from the 720 to the 940 the 940 refused to boot up just cycling the start-up screen
thanks Terry
PostPosted: Thu Jan 15, 2009 6:24 pm    Post subject: Reply with quote
On the 720, convert your Favourites to POIs.
FIRST
Change Preferences
Manage POIs
Add POI Category
Give it a name (e.g. My Favs!) Edit If you give the name a leading underscore, _My Favs, the category name will appear at the front of the alphabetical list for when you want to use it. (Navigate to POI it will be the first POI category listed).
SECOND
Change Preferences
Manage POIs
Add POI
select My Favs (POI category)
select to create from Favourite
choose the favourite
keep or rename it
Do SECOND above for all your favourites.
THIRD
Connect to PC and using Windows Explorer, copy the POI Category Favourites from your map folder to your Hard Disk, then copy them to the map folder on 940. If you can connect both devices at the same time (enough USB sockets), you could miss out the copying to Hard Disk. However, having a copy of your POI Favourites is not a bad thing.
Trevor1234
PostPosted: Thu Jan 15, 2009 9:34 pm    Post subject: Reply with quote
Hi DennisM
I know your method of transferring favourites as POI is the accepted one but I find saving favourites as an Itinerary destination quicker and simpler.
Itineraries are always saved on the computer during backups and it’s a simple task to copy them from the backup and paste them into the Itinerary folder on the new device. Once there one can easily save them as favourites once again.
Tomtom Go 720.
Navcore 9.510
GPS World Traffic cameras
Home 2.7
iPhone 3G
PostPosted: Thu Jan 15, 2009 11:00 pm    Post subject: Reply with quote
That looks's like a nice idea...
Just one thing.... I can see it is very quick to add all your Favourites as itinerary entries, but I can't see a really quick way of re-saving them as favourites.
The best I can see is to:
1. Highlight first entry
2. Tap "Show on map"
3. Tap Blue cursor button
4. Tap "Add as favourite"
5. Repeat for all others
Is there a quicker way I've missed?
Trevor1234
PostPosted: Fri Jan 16, 2009 12:26 am    Post subject: Reply with quote
Hi Andy_P
Well, I admit that I do not have a great number of favourites and so I can add the ‘Show On Map’ to Favourites pretty quickly. I have never tried the POI method but it looks a bit complicated to me. However, the POI method seems to be the accepted way of doing things and so I suppose it must be the best way.
I have always saved my favourites as an Itinerary destination into a folder on my PC and so even when I have deleted any favourites from my device they still remain safe. Even if I was to loose my device they would be safe and snug on the computer.
Tomtom Go 720.
Navcore 9.510
Home 2.7
iPhone 3G
PostPosted: Fri Jan 16, 2009 12:41 am    Post subject: Reply with quote
Sounds like six of one and half a dozen of t' other. Both methods require you to use Favourites to create either itinerary or POI. I have no knowledge of the comparative ease of either method - I created my POIs ages ago and no doubt you did the same with your itinerary. I get the feeling your method needs one more step (for each point) than the POIs, namely converting back to Favourites from itinerary - if I have 20 Favourites, I convert them once to POI and use POI from then on. I think you're saying your method is to create itinerary from 20 Favourites, then convert each one back again individually to Favourites when you restore the device from backup?
PostPosted: Fri Jan 16, 2009 1:37 am    Post subject: Reply with quote
No! Not necessarily at all!
I wasn't trying to 'do it down' in my last post, I was genuinely asking a question! (sorry if it didn't come across like that).
I really like your method, I think it *will* be quicker (less button presses I think), and I'll definitely be adding it to a write-up of the various different methods that I did.
I just wanted to check I wasn't missing a trick first. Thumbs Up
tez
PostPosted: Fri Jan 16, 2009 8:38 am    Post subject: Reply with quote
Thanks for the help I will give it a go either way I have not decided yet Very Happy
Thanks Terry
tez
PostPosted: Sat Jan 17, 2009 6:14 pm    Post subject: Reply with quote
Hi all I have done the above DennisN's way and cant seem to find them on my 940.
I put the file "POI.DAT"in the western map folder on the 940.
where should they be?????
Thanks Terry
tez
PostPosted: Sat Jan 17, 2009 6:39 pm    Post subject: Reply with quote
I think I may have sorted this now
I am just doing a restore on the 940 and will then copy and paste the "my fav.ov2" file to my 940.
this should be it I asume..
thanks Terry
tez
PostPosted: Sat Jan 17, 2009 7:00 pm    Post subject: Reply with quote
Hi all
it's now done thanks again
Terry Very Happy
PostPosted: Sat Jan 17, 2009 8:21 pm    Post subject: Reply with quote
Sorry to leave you out on a limb tez, I've been out. You must have felt you were talking to yourself. Still, you talked yourself into the solution anyway, good on yer! (By "Restore" I hope you mean "Backup"). Thumbs Up
tez
PostPosted: Sun Jan 18, 2009 6:38 pm    Post subject: Reply with quote
Hi Dennis
yes using TomTom home!!!!! any way thanks for the help I have now sorted it out and have all my Fav's on my 940.
Regards Terry
PostPosted: Sun Jan 18, 2009 10:29 pm    Post subject: Reply with quote
tez wrote:
Hi Dennis
yes using TomTom home !!!!! any way thanks for the help I have now sorted it out and have all my Fav's on my 940.
Regards Terry
Oh Terry! Does this mean you used TT Home to backup/restore. Please tell me you were only kidding and you really use Windows Explorer for backups.
nigelmuskett
PostPosted: Mon Jan 19, 2009 8:34 pm    Post subject: Reply with quote
Must admit just to be difficult I used a third method to transfer my favourites from my old 910 to the 940 and that was to open the saved mapsettings.cfg in poiedit to get the locations and then on the 940 add favourites as latitude/longitute locations.
