Pocket GPS World :: View topic - Custom warning sounds for 540 LIVE?
markmcrobie
PostPosted: Fri Dec 19, 2008 11:35 am    Post subject: Custom warning sounds for 540 LIVE? Reply with quote
I've got decent custom sounds for most of the available camera types on the 540, but I was wondering if anyone has some links to a full set (i.e. voices for all the speed cam types plus accident blackspot, unguarded level crosssings, etc)
MrT
PostPosted: Fri Dec 19, 2008 12:04 pm    Post subject: Reply with quote
Did you know that it can read out the names of the POI files so if your POI file was called "30 MPH Gatso.ov2" it would say "30MPH gatso 200 yards"? That is how I have set mine up, no extra sound files needed.
Drivelux
markmcrobie
PostPosted: Fri Dec 19, 2008 12:30 pm    Post subject: Reply with quote
How do I set it to do that?
MrT
PostPosted: Fri Dec 19, 2008 2:17 pm    Post subject: Reply with quote
This only works from the unit, does not work from TTHome.
Change preferences
Next screen
Manage POIs
Warn when near POI
Select the POI
Select a warning distance
Select Brief Spoken Warning
Done
Select Warn only if POI is on route (if required, I wouldn't)
Done
Repeat for each POI
I rename my camera POI files to the warning I want.
Drivelux
PostPosted: Fri Dec 19, 2008 2:21 pm    Post subject: Reply with quote
That wont work for the TomTom supplied cameras though will it?
markmcrobie
PostPosted: Fri Dec 19, 2008 2:28 pm    Post subject: Reply with quote
No, so my original question still stands - does anyone know where I can get a voice pack that covers ALL the warning types for the TomTom camera database?
Failing that anyone know if I could use my Mac to type in some text, then have a computer voice read it, and capture it? I have capture software (Audio Hijack), so it shouldn't be THAT difficult?
MrT
PostPosted: Fri Dec 19, 2008 2:42 pm    Post subject: Reply with quote
Do you want voices on TTs own camera warnings? I just use them on the PGPSW cameras as they are more accurate and I don't want two spoken warnings for cameras where both databases identify the same camera.
On the PGPSW cameras they are broken down by speed and type so the warning will be 30mph mobile camera rather than camera.
If you scroll down the list of sounds available for the TT cameras there is a record your own warning option.
Drivelux
PostPosted: Fri Dec 19, 2008 4:26 pm    Post subject: Reply with quote
Just use the device's text to speech system with the audio of the TomTom feeding the line out socket.
Connect the Line out socket of the TomTom to the PC sound input socket.
Record each warning you want on the PC as a wav file and once you have a full set copy the files to the "sounds" folder on the device, these sound files will then be available for selection against the Safety Cameras.
The above does assume you have an accessory mount for your 540 with the audio line out socket, if not perhaps an easier option is below:
Use the Speed Camera database from this site and the preconfigured warning files, this is a much more comprehensive package, easier to setup and far more accurate - Mike
Tomo
PostPosted: Fri Dec 19, 2008 9:52 pm    Post subject: Reply with quote
Or just convert the .OGG files that are supplied with PGSW database to .WAV files and drop them in the sounds folder then select them for each TT camera type.
I have done this and works ok.
Reason Im doing it?
Well, have used the PGSW database for almost a year now but just updated to a 540 Live and thought I would give the TT supplied database a try for a few weeks to see how it fairs compared with the PGSW database.
Only had the 540 for 2 days so too early to comment on the TT database, although I dont hold up much hope for it been better than the older TT database supplied with Plus services on older devices.
Steve
PostPosted: Sat Dec 20, 2008 7:27 pm    Post subject: Reply with quote
Mike Alder's suggestion of using the in-built TTS voice will give the best results if you have access to the line output, (that's how I did the "Simon" voice set for the PGPSW cameras), but if you want to do it all on the PC, here are some TTS websites I had bookmarked:
http://www.research.att.com/~ttsweb/tts/demo.php
http://www.oddcast.com/home/tts
http://www.text-speech.com/download.htm
http://www.cepstral.com/demos/
PostPosted: Sat Dec 20, 2008 7:51 pm    Post subject: Reply with quote
I think Mark is slightly ahead of this thread by now - try Here - Mike
22.052 (08 May 24)
