Pocket GPS World :: View topic - Never Updated TOMTOM 910, advice please?
bbasra
PostPosted: Sun Nov 16, 2008 3:28 pm    Post subject: Never Updated TOMTOM 910, advice please? Reply with quote
Since i bought my 910 around x years ago, I've never updated it.
It's working fine and has the pocketgpsworld cams and poi's.
I'm doing a backup of it now using TT Home and also will be doing a copy via Windows Explorer.
I would like the new 8.15 new map and guessing i'll need to update the software to v7.xxxx as I'm running version v6.xxxx.
what will the update do and is it worth doing just for the newer map.
I have a TomTom 910.
PostPosted: Sun Nov 16, 2008 3:35 pm    Post subject: Reply with quote
Please make sure you do perform a Windows Explorer back up, TomTom Home backups with the 910 had a nasty habit of re-naming all the files and folders in the LoquendoTTS folder leaving you without any Text To Speech on the device.
You will notice some changes to the way the RDS-TMC works (if you use it) and the map will contain newer road layouts, not much else of any note as I recall - Mike
bbasra
PostPosted: Sun Nov 16, 2008 4:04 pm    Post subject: Reply with quote
never used RDS-TMC.
There also lots of posts about v7.900. uuummmm :-s
bbasra
PostPosted: Sun Nov 16, 2008 5:05 pm    Post subject: Reply with quote
is v7.900 the latest for the 910?
Just upgraded and can't go any newer.
sphelps
PostPosted: Sun Nov 16, 2008 5:30 pm    Post subject: Reply with quote
bbasra wrote:
Yes it is, and I didn't realise there was an update yesterday when I connected my 910 to TT Home and it installed it.
Nothing but problems with it. Caused no end of problems with map displays etc, and would not run for more than a couple of minutes and then re-boot, and you would have to re-enter your route again.
Luckily I had a Windows Explorer backup of 7.165 and all is working as before. Thanks to all who keep telling us TT users to do a Windows Exploere backup.
Regards
Steve
TomTom 720 Version 8.302 Map WCE v825
Navigon 40 Premium
COLINRG
PostPosted: Sun Nov 16, 2008 11:21 pm    Post subject: Reply with quote
Don't bother updating past V6. Any further and you will encounter problems. Wait till TomTom release a further update to 7.900 before updating. You won't be able to use the RDS-TMC feature fully if you update above V6.
I've had an ongoing issue with TomTom regarding the 910 and RDS-TMC to the tune that TomTom are providing a new 920T FOC.
If by some other method you update you 910, it will run 8.010 and early version 8 maps. But that's another dark alley Shocked
dhn
PostPosted: Sun Nov 16, 2008 11:31 pm    Post subject: Reply with quote
But wasn't the fix for the rds issue vis-a-vis 7.9 here in the second last post?
bbasra
PostPosted: Mon Nov 17, 2008 3:11 pm    Post subject: Reply with quote
i ended up upgrading to the latest v7 and all seems to be fine. Don't know how people are upgrading to version 8 as it's does give me the update.
I don't use RDS-TMC and never have done so.
I did do a backup using explorer but i forgot to show all hidden files and then copy it. :-(
PostPosted: Mon Nov 17, 2008 6:39 pm    Post subject: Reply with quote
Shouldn't matter... As supplied, there are NO hidden files or folders on a TomTom.
22.044 (24 Apr 24)
