Pocket GPS World :: View topic - Kenwood DNX5220BT error message
jengo22
PostPosted: Sun Sep 21, 2008 1:58 pm    Post subject: Kenwood DNX5220BT error message Reply with quote
I am trying to load the safety cameras onto my Kenwood DNX5220BT but each time I enter the disk I get DISK ERROR.
I am using the garmin point loader and when I have downloaded the safety file I save as garmin\POI.gpi. Can anybody advise where I have gone wrong?
Many Thanks
Jengo22
fokkerjet
PostPosted: Wed Oct 15, 2008 2:46 pm    Post subject: Reply with quote
Make sure that you have closed off your disk when you burn it. Check the "settings" button before you burn and ensure that there is a tick in the box to "finalise setting" or something similar.
Also, on your Kenwood unit, you need to go into SYSTEM SETUP menu and check that it says CD READ 1. If it says CD READ 2, change it and hopefully your problem will be solved. Good luck.
bobbybosco
PostPosted: Fri Oct 24, 2008 7:02 pm    Post subject: kewood 5220 Reply with quote
i have just went through the exact problem. you have done the first part right .the most important thing is that you dont try to burn the files using windows .you have to use somthing like nero or roxio. plus make sure your points of interest on your kenwwod are turned on
mort66
PostPosted: Fri Nov 14, 2008 12:31 pm    Post subject: Reply with quote
what do you burn as with nero ? data cd keep getting unexpected file error
PaulB2005
PostPosted: Fri Nov 14, 2008 12:33 pm    Post subject: Reply with quote
What is the exact error message and when do you get this? Before you burn, during the burn, once you put it in to the Kenwood?
Make sure you burn as a Data CD and you finalise the disk. Also use good quality brand name media.
mort66
PostPosted: Fri Nov 14, 2008 12:36 pm    Post subject: Reply with quote
nero wont let me burn the file as data cd
PaulB2005
PostPosted: Fri Nov 14, 2008 12:40 pm    Post subject: Reply with quote
Have you got the latest version of your Nero?
Have you tried deleting the files and redownloading them? They are just normal bmps and csv (Text) files so Nero shouldn't have any problems burning them.
mort66
PostPosted: Fri Nov 14, 2008 12:42 pm    Post subject: Reply with quote
nero only shows the file when i click all files in drop down box and when i try to burn it says unexpected file format
PaulB2005
PostPosted: Fri Nov 14, 2008 1:06 pm    Post subject: Reply with quote
What does it say in the drop down box before you change it to "All Files"? If you are burning in Data format then it's shouldn't have any preconception of the types of files you want to burn, unlike, say Music CD, where it'll try to filter out non-music files first.
mort66
PostPosted: Fri Nov 14, 2008 5:29 pm    Post subject: Reply with quote
BURNED ONE WITH NERO EXPRESS BUT GET ERROR MESSAGE ON KENWOOD
PaulB2005
PostPosted: Fri Nov 14, 2008 5:39 pm    Post subject: Reply with quote
Any chance you can tell me what the message was?
mort66
PostPosted: Fri Nov 14, 2008 6:31 pm    Post subject: Reply with quote
sorry, started to read disk then just said error ,no code after it. am downloading roxio to see if that will do the trick
PaulB2005
PostPosted: Fri Nov 14, 2008 6:50 pm    Post subject: Reply with quote
Did you read the first and second post in this very thread??
mort66
PostPosted: Fri Nov 14, 2008 6:55 pm    Post subject: Reply with quote
yep and nero is set to finalise disk
PaulB2005
PostPosted: Fri Nov 14, 2008 6:59 pm    Post subject: Reply with quote
What about
