FJRFaz Occasional Visitor
Joined: Apr 25, 2007 Posts: 4 Location: United Kingdom
Posted: Wed Aug 13, 2008 8:17 pm Post subject: Cameras not showing |
Have TT 6.030 on my Xda. Have updated my maps to complete west europe. Have put Cam files into the map folder but it won't show them, Shows all other POIs but not the cameras.
HELP!!!
Matt |
rfp2001 Lifetime Member
Posted: Wed Aug 13, 2008 8:45 pm Post subject: |
You need to go into "Enable/Disable POI's", find the camera list then tick each box one by one and select the warning distance and then sound preference for each one.
Is that what you want or are you saying that the cameras are not shown at all in "Enable/Disable POI's"?? |
Posted: Wed Aug 13, 2008 8:56 pm Post subject: |
Not showing at all in POI enable/disable. Has all the other POIs there but no cameras.
Matt |
Posted: Wed Aug 13, 2008 9:40 pm Post subject: |
Have you actually enabled/ switched to the new map? - try Change Preferences/ Manage Maps/ Switch map and select the Western Europe Map from the list - the device might be still using the old map if its on the same memory card - Mike |
Posted: Wed Aug 13, 2008 9:56 pm Post subject: |
Thanks Will give that a try
Matt |
