Pocket GPS World :: View topic - Importing POIs
Importing POIs
p-brain
PostPosted: Tue Jul 15, 2008 6:52 pm    Post subject: Importing POIs Reply with quote
I would like to import a list of POIs (as a gpx file). I can do this no problem via SatSync.
However, ideally I would like to import them, and subsequently imported POIs, into a specific 'category', or move them into a specified category once imported.
Is this possible?...or does each import create a new POI category?
(I use the Satmap for Geocaching and have created a POI category called 'Caches'. Thefore whenever I import a new cache, I would like it to appear under the 'Cache' category of POIs)
p-brain
PostPosted: Sun Jul 20, 2008 10:57 am    Post subject: Reply with quote
OK, as nobody seems to be able to comment on this...I will answer my own question! On further investigation this does not appear to be possible.
FrequentFlyer
PostPosted: Sun Jul 20, 2008 11:17 am    Post subject: Reply with quote
Surely, when you highlight the Cache POI category, hit Edit, then create your new POI by map or grid reference, and hey presto..(I think.) You will then have to edit its proper description though...instead of, eg POI 58 or whatever it says.
p-brain
PostPosted: Sun Jul 20, 2008 12:22 pm    Post subject: Reply with quote
Hi, yes you are correct - however, I am referring to waypoints/POI's uploaded to the A10, not created with the A10. I want to be able to upload (or move) POI's to a specific category.
Westlothian
PostPosted: Wed Dec 10, 2008 1:03 am    Post subject: Import of POIs Reply with quote
I managed to get POIs imported from a gpx file.
This was exported from Live Maps to generate the code.
No route was selected only a collection of "push-pins".
22.044 (24 Apr 24)
