Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Tue Jun 17, 2008 12:58 am Post subject: |
See Darren's had his wand out again |
Kolster Occasional Visitor
Joined: Apr 01, 2006 Posts: 42 Location: Sunny Southport
Posted: Tue Jun 17, 2008 6:36 am Post subject: |
philpugh wrote: | Kolster wrote: | Hi,
Like to give these a try, but not quite sure about how to load them, do you put them in the same as the speed cameras, and as I'm using a Nuvi350 with the Emily TTS voice, would there be a problem here?
John |
Feekus has got them all named correctly so you should copy them into the same folder that you have the PGPSW safety camera database in and run POILoader to recreate the POI.GPI file. It does not affect the navigation voice you use. You will need the speed-zoned cameras for these to work.
Cheers Phil
John |
Feek Lifetime Member
Joined: Mar 04, 2008 Posts: 173 Location: Englandshire.
Posted: Tue Jun 17, 2008 8:32 am Post subject: |
Right, that was much better - I had the master volume set to 80% and the navigation sounds set to 90% and the warnings were nicely loud and punchy. I'm happy with these, but would obviously still like feedback from anyone else who has tried them. |
Posted: Tue Jun 17, 2008 5:06 pm Post subject: |
Must be doing something wrong here, I've downloaded Feeks voice file and the latest speed zoned camera file to new directory, unzipped them both and ran the POI loader on this directory, it installed 13 thousand plus POIs but it still just bongs without any voices, can anyone suggest anything please?
John |
Darren Frequent Visitor
Posted: Tue Jun 17, 2008 5:13 pm Post subject: |
Don't you have to manually copy the voice files onto the device? I'll have a play on my 760, not very 'up' on Garmin's! _________________ Darren Griffin |
philpugh Lifetime Member
Posted: Tue Jun 17, 2008 5:56 pm Post subject: |
Darren wrote: | Phil, if you or anyone else has gone to the trouble of converting the files we already host into Garmin compatible formats, I'd be happy to host them and add them to the download page for the benefit of other Garmin users? |
i'll zip them up and drop a pm!
Phil _________________ Phil |
Posted: Tue Jun 17, 2008 5:59 pm Post subject: |
Darren wrote: | Don't you have to manually copy the voice files onto the device? I'll have a play on my 760, not very 'up' on Garmin's! |
I use Ash10's CameraManager utility - it does it all automatcally. BUT you shouldn't have to copy the sound files over - POILoader is supposed to merge everything into the .GPI and move this into the correct nuvi location. Just carefully check the file names - they looked OK at first glance - I'll try them out tonight! _________________ Phil |
Posted: Tue Jun 17, 2008 6:05 pm Post subject: |
Just tried it on mine on a short local run and still playing the default beeps. Are these only supported on some devices? _________________ Darren Griffin |
Dilcymro Frequent Visitor
Posted: Tue Jun 17, 2008 6:38 pm Post subject: |
Hi all, I also have installed the voicefiles into the same folder as the speedcams and poi`s and inputed onto my garmin nuvi 360 with the latest poi loader ver 2.5.2.0.
On a run out this afternoon and all I got was the normal "very quiet" bongs.
Any chance of a detailed "How to" please as I must have gone wrong somewhere
Thanks in advance....dilcymro |
Posted: Tue Jun 17, 2008 6:39 pm Post subject: |
As far as I'm aware they should work on any Nuvi, certainly works on my 760 with no problems. |
Posted: Tue Jun 17, 2008 6:53 pm Post subject: |
Do you install straight onto the nuvi or an SD card. Is there anything that needs to be set on the mp3 player?, Do you need to turn the bongs off in the settings at all?
Any help =info appreciated. _________________ ***************************************
Garmin Nuvi 2415
Where there`s a Dil ---- There`s a way
Posted: Tue Jun 17, 2008 6:55 pm Post subject: |
Feek wrote: | As far as I'm aware they should work on any Nuvi, certainly works on my 760 with no problems. |
Ah, just checked the file names don't match!
You have:
PocketGPS_UK_Gatso_Fifty.mp3
and the POI file name is:
pocketgps_uk_gatso_50.csv
I'll rename and re-test! _________________ Darren Griffin |
Posted: Tue Jun 17, 2008 6:59 pm Post subject: |
Darren wrote: | Feek wrote: | As far as I'm aware they should work on any Nuvi, certainly works on my 760 with no problems. |
So Camera POIs and .mp3s in the same folder on the computer and then run POILoader against that folder? No other steps? |
Exactly that - Here's what my POI directory looks like.
http://www.ukrm.org/feek/temp/poi-20080617-185920.png |
Posted: Tue Jun 17, 2008 7:02 pm Post subject: |
Darren wrote: | Ah, just checked the file names don't match!
You have:
pocketgps_uk_gatso_50.csv |
That would do it - I use Ash's camera manager doofer to download them so I simply named the files as appropriate for the files that produces. |
Posted: Tue Jun 17, 2008 7:07 pm Post subject: |
OK, I have renamed to match our speed zoned file naming convention.
They can be downloaded here for now, once we're all happy I'll add to the main sound files download page
Download Link _________________ Darren Griffin |
