Pocket GPS World :: View topic - Camera Positions
Camera Positions
hudster
PostPosted: Sun May 04, 2008 10:16 am    Post subject: Camera Positions Reply with quote
when out and about, I've noticed that the camera positions of a few cameras near me are out by about 100 meters, some have been relocated to make the camera easier to see, but some are just shown in the wrong locations.
To get the correct position, do I need to report them as new locations, or is there an easier way to report the correct camera position?
PostPosted: Sun May 04, 2008 10:33 am    Post subject: Reply with quote
If you go to the Camera Page, you can put the Camera's ID number into the ID Box and click autofill. The Action Box, to the left, should default to Change Existing Camera.
Going down to the Map now, it should be centred on the Camera in question. Drag the Map so that the Cross-hair is placed where you think the camera should be.
Just above the Map, Click on Button Update Co-ordinates for Single Submission. Click Confirm correct country and then Send Entry.
I think I've covered everything. Smile
PostPosted: Sun May 04, 2008 10:56 am    Post subject: Reply with quote
As this is a correction you should report it as 'change existing camera'.
On the submission map, locate the existing camera and note it's camera ID#.
Then using the cross-hairs, locate the correct position or enter the co-ordinates if you have them. Add a note in the Details & Description filed explaining that this is a correction as the camera has been re-located.
If you can also fill out as many of the other boxes as known, i.e. direction, speed, type etc it all helps speed up the verification process Smile
22.052 (08 May 24)
