Pocket GPS World :: View topic - Icon Removal
Icon Removal
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion
MrCool
PostPosted: Sun May 09, 2004 2:14 pm    Post subject: Icon Removal Reply with quote
I tried to install Wisbar but somewhere along the way it went wrong and failed to work, i removed the software but i still have the Wisbar Advan icon showing in the program screen and i can`t remove it, whats the secret ?
I`m using PPC 2002.
Thanks in advance.
DavidW
PostPosted: Sun May 09, 2004 2:56 pm    Post subject: Reply with quote
The answer is actually the same for Pocket PC 2002 and Pocket PC 2003.
You need to find the redundant shortcut in the \Windows\Start Menu folder (or one of the folders inside that folder) on your Pocket PC.
There's two ways to do this - either use a file manager on your Pocket PC (the rather limited built-in one will do - go to My Device, then Windows, then Start Menu), or use the Explore function in ActiveSync (press the Explore button in ActiveSync or Mobile Device in an Explorer Window, then My Pocket PC, Windows, Start Menu).
MrCool
PostPosted: Mon May 10, 2004 10:08 am    Post subject: Reply with quote
thanks David easy when you know what you`re doing
DavidW
PostPosted: Mon May 10, 2004 1:12 pm    Post subject: Reply with quote
My pleasure - I inadvertently left out the instruction to delete the offending shortcut(s) when located, but I presume that much was obvious.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion All times are GMT + 1 Hour
22.053 (15 May 24)
