alpeters Occasional Visitor
Posted: Fri Mar 14, 2008 3:07 pm Post subject: Info on hgv poi's please |
Just wondering if there is a cd rom for sale out there or a site i can buy the following pois for my tomtom 910
Low Bridges (all of them if possible)
Width
Weight
Industrial estates
Truck stops (like my grub and the odd shower)
Any help on this matter would be great thanks very much in advance.
AL _________________ Via 125 Live
English By Birth Lancastrian by The Grace Of God |
alix776 Pocket GPS Moderator
Posted: Fri Mar 14, 2008 7:58 pm Post subject: |
http://trucknav.napalmfiles.com/ try here _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
jas07 Occasional Visitor
Posted: Wed May 07, 2008 10:38 pm Post subject: |
Thats Brilliant, cheers fellas! |
tangray1 Occasional Visitor
Posted: Mon May 19, 2008 4:29 pm Post subject: |
Hi there sorry to be a complete idiot but is there a guide on how to use and instal these files on to my tt910 ,don`t want to it up doing it wrong ...many thanks..  |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10632 Location: Suffolk, UK
Posted: Mon May 19, 2008 7:17 pm Post subject: |
Have a look at This.
That should give you a good grounding in what to do.
If there's anything you don't understand, or you hit a snag, just come back with the problem.  _________________ Richard
TT 910 V7.903 (9183/081205) OS:2344
Europe version 1045.10005
TT Via 135 App 12.075
Western Europe v1082 |
tullyh Occasional Visitor
Joined: May 04, 2008 Posts: 21 Location: County Down Northern Ireland
Posted: Mon May 19, 2008 11:35 pm Post subject: |
alix776 wrote: | http://trucknav.napalmfiles.com/ try here |
That would be excellent if I could find them in csv format for a Garmin Nuvi. Googling without success atm, can anyone point me in the right direction please?
TIA |
Posted: Tue May 20, 2008 7:38 am Post subject: |
Download and install POIEdit to your PC, use this application to open the ov2 file then choose "Save As" and select Garmin csv to save the file, the resultant data will be in the correct format for your Garmin - Mike |
Posted: Tue May 20, 2008 8:33 am Post subject: |
mikealder wrote: | Download and install POIEdit to your PC, use this application to open the ov2 file then choose "Save As" and select Garmin csv to save the file, the resultant data will be in the correct format for your Garmin - Mike |
Quick post before work, I indeed found POIedit late last night, downloaded it and found I could change file formats to csv. However the low bridge downloaded files where in ov2, ogg and bmp formats. I wasn't sure which ones and how many I needed to convert and load on the Nuvi. If I convert the relevant ov2 file to csv and load it and appropriate bmp with POI loader to my Nuvi does it magically display the correct bridge height bmp and red banner/audible warning when appraching a low bridge? There is approx 10 different heights of bridges and bmps so above X10 all POILoader'd at the same time?
The other problem was I browsed through the huge list of locations on the database and could not find any in Northern Ireland which is where I need them. They may be there but I suspect its a mainland database only.
TIA |
Anita Pocket GPS Moderator
Posted: Tue May 20, 2008 9:00 am Post subject: |
tullyh wrote: | The other problem was I browsed through the huge list of locations on the database and could not find any in Northern Ireland which is where I need them. They may be there but I suspect its a mainland database only. |
May I suggest that you might receive more relevant advice if you edit your profile to include your location.
I've never understood the reluctance to include at least the country, and preferably the county or region, as it really does make a difference to those trying to help.  _________________ Anita
TomTom VIA 135 - App 12.075,
UK map 1090.11467
Samsung Galaxy S8 |
Posted: Tue May 20, 2008 4:06 pm Post subject: |
Anita wrote: | May I suggest that you might receive more relevant advice if you edit your profile to include your location.
I've never understood the reluctance to include at least the country, and preferably the county or region, as it really does make a difference to those trying to help.  |
Done, not a reluctance on my part, it just never occurred to me that it may help.  |
Posted: Tue May 20, 2008 4:31 pm Post subject: |
Thanks!
Sorry, re-reading that it didn't come across as the friendly suggestion it was meant to be.
It wasn't really just aimed at you. So often people can spend their time trying to give help based on their UK knowledge and experience then, several posts later, the OP just happens to mention that they're in the US, so none of the advice was relevant to them. This can be very frustrating for those requesting help and those trying to give it, which can be avoided if members give some indication of their location. _________________ Anita
UK map 1090.11467
Samsung Galaxy S8 |
Tecka133 Occasional Visitor
Posted: Mon May 26, 2008 10:31 pm Post subject: |
Hi, all good info so far.
I'm a newbie to this and have tried to convert the files for use on Garmin streetpilot c550 but can't get any of the files onto the system.
Does anyone have any ideas of what I could try.
Thanks in advance
Tecka |
Posted: Mon May 26, 2008 10:55 pm Post subject: |
Quote: | I'm a newbie to this and have tried to convert the files for use on Garmin streetpilot c550 but can't get any of the files onto the system.
Does anyone have any ideas of what I could try. |
Hi and welcome.
It might help if you told us what you did do and where it doesn't work. Please include any error messages. |
Posted: Tue May 27, 2008 7:06 am Post subject: |
Yeah I followed the brief instructions above, opened and extracted files fine. used poiedit to open and save as .csv
From here I try to use poi loader to install on gps but it can't find suitable files. I've obviously missed something, Not sure what companion files are needed for Garmin?
Thanks again for helping to stop my brain melting! |
Posted: Tue May 27, 2008 7:32 am Post subject: |
What is the exact error message, please? |
