Pocket GPS World :: View topic - 520 showing actual position of vehicle about 100 yards out
Goto page Previous  1, 2, 3, 4, 5, 6, 7
DeLorean
PostPosted: Wed Mar 05, 2008 8:23 am    Post subject: Reply with quote
I doubt it's the satellites at fault.
If this were so, then it would hit the global news Exclamation
It’s not just car drivers who rely on GPS.
Airplanes, emergency services and the military to name a few use GPS and if this problem was satellite related it would be a catastrophe Shocked
As I mentioned in an earlier post, my TomTom Home updated my TT910's GPS firmware a few weeks back.
Possibly a glitch in the newer firmware Question
Let’s see what happens Confused
🔸🔸 Currently using TomTom GO 940 & Locus Map 🔸🔸
lowie
PostPosted: Wed Mar 05, 2008 9:57 am    Post subject: Reply with quote
Oldboy wrote:
Philgo wrote:
What happens if the contents of the ephem folder is deleted, will the TomTom then show it's correct position. Surely anyone with this problem can try that, then then quickfix will be found guilty or innocent.
My Ephem Folder is always empty and it has no problem getting a fix and, so far, I've always been correctly located. Smile
lowie wrote:
Even better when I checked the time sync it was 12 hours behind and still is despite leaving the unit on for a couple of hours.
Sync will only adjust the Minutes, not the Hours, which you have to do to allow for the Time Zone difference.
It might be 12 hours ahead. Wink
My time zone is UK and the time shown on the satellites is the same. Before I had the repair done the time sync was spot on even between am and pm so there does seem to be some issue with it.
PostPosted: Wed Mar 05, 2008 10:38 am    Post subject: Reply with quote
It could have easily been changed by an engineer, or the battery disconnected.
Correct the hours now and for the next 3 weeks it will maintain time accuracy. Then it will be out of sync with UTC anyway. Smile
PostPosted: Wed Mar 05, 2008 10:46 am    Post subject: Reply with quote
Should he care about being in synch with Université de Technologie de Compiègne? (You're lucky - I was about to roast you for acronyms again, Richard, but fortunately Andy gave me this dinky little website Bookmark that explains them all to me).
GPS_fan
PostPosted: Wed Mar 05, 2008 10:59 am    Post subject: Reply with quote
There's usually a small backup battery or capacitor to retain settings etc when the main battery goes flat.
It's this which is likely to have been disconnected during the repair, but it might be worth checking that your settings aren't lost when the battery goes flat because if you don't check it soon, they could argue that you're no longer covered by the repair warranty
Andy
PostPosted: Wed Mar 05, 2008 11:34 am    Post subject: Reply with quote
I would do, but by the time I get home, it's always corrected itself.
What it really needs is a laptop in the car and a quick delete WHILE the problem is happening.
portman
PostPosted: Wed Mar 05, 2008 11:44 am    Post subject: Reply with quote
It always happens at sunset for me, so from about 6pm onwards.
Samsung Mega
Tomtom 500
PostPosted: Wed Mar 05, 2008 1:16 pm    Post subject: Reply with quote
Why not do it before hand. It only uses that Folder as Read Only Data. Without it, it's acquisition of Satellites is as it always has been.
If it's deleted and you still get the problem, then it's not a QuickFix problem.
Johnny_D
PostPosted: Wed Mar 05, 2008 2:04 pm    Post subject: Reply with quote
Well, just to throw my spuds on this fire...
This happened once and once only when i first used the unit for a brief time. Having read through this debate I removed the ability to download the quickfix thing and deleted that file people have been refering too.
Never had a problem since.
V715 Map & Latest software on TTG.
JD
TTG 300 Died the death of a cracked screen
Navman F20 USB Fell off
TTG 520 Third time lucky?
Bloody Superb PGPSW Camera Database.
Not much else!
Wazza_G
PostPosted: Sat Mar 08, 2008 10:42 am    Post subject: Reply with quote
This is weird my system is now spot on again, if not more accurate...
I did an update yesterday then took it out and it was accurate within a matter of feet, let alone yards! Shocked
I've also noticed that the number of Mapshare corrections has jumped from the 7,000 range to over 50,000!
It seems things are getting seriously weird on planet Tom Tom. Laughing
PostPosted: Sat Mar 08, 2008 5:15 pm    Post subject: Reply with quote
I NEARLY did what you suggested that day, but ran out of time so didn't get round to it.
I then drove home and the TT behaved faultlessly, so if I HAD deleted that folder I'd now be convinced that's what had fixed it.... Neutral
StanStill
PostPosted: Tue Mar 18, 2008 2:56 pm    Post subject: Reply with quote
You are all wrong! I remember soon after I got my Go original I had this happen once on a motorway. I had a search through old posts and came across this.
All these people did not have Quick fix at the time and most seemed to blame atmospheric conditions.
Sorry I cannot remember how to simplify url's
Link edited for you - Oldboy
Page 7 of 7
22.052 (08 May 24)
