Martin4Jay Regular Visitor
Joined: Aug 02, 2005 Posts: 150 Location: Monkton Heathfield, Somerset
Posted: Sun Feb 10, 2008 10:32 am Post subject: Navman s90i Poi's |
I had a look on Pocket GPS poi's notice it shown for Tom Tom or other (CSV) when I try the CSV it just goes back to the Tom Tom. I also tried this on the firefox and had the same problem. Can anyone tell me is there any poi's for the Navman s90i?
Thanks _________________ Life is like a bunch of cherries, you don't know who is going to get on your pip.
Just be truthful and follow your heart
Life is how you make it
I'm forever blowing bubbles
I'm now a happy Garman Man |
Posted: Sun Feb 10, 2008 10:43 am Post subject: |
I have just tried a download of csv files and they work fine you do need to reselect csv for each different download, which part isn't working for you? - Mike |
Posted: Sun Feb 10, 2008 10:58 am Post subject: |
mikealder wrote: | I have just tried a download of csv files and they work fine you do need to reselect csv for each different download, which part isn't working for you? - Mike |
Hi Mike
When I look on the Pocket GPS poi's do I select the Tom Tom (OV2) there is only two options in the list.
P.S this is for the 200,000 Points of Interests (POIs) _________________ Life is like a bunch of cherries, you don't know who is going to get on your pip.
Posted: Sun Feb 10, 2008 11:03 am Post subject: |
Other CSV is the type of download you should select - Mike |
Posted: Sun Feb 10, 2008 11:11 am Post subject: |
mikealder wrote: | Other CSV is the type of download you should select - Mike |
Mike I tried the refresh for the CSV but it refreshes back to Tom Tom I also tried this on firefox and it did the same.
Cheers _________________ Life is like a bunch of cherries, you don't know who is going to get on your pip.
Posted: Sun Feb 10, 2008 11:16 am Post subject: |
Select csv and then continue to make your POI selection, finally you then select the download to get the files you require, do not refresh the page as that will reset it back to default - Mike |
Posted: Sun Feb 10, 2008 11:27 am Post subject: |
mikealder wrote: | Select csv and then continue to make your POI selection, finally you then select the download to get the files you require, do not refresh the page as that will reset it back to default - Mike |
Thanks Mike that has done the trick.
To put the Poi's in the s90i would I use the same instructions as for the speed cams?
Hoping you will understand me
Martin _________________ Life is like a bunch of cherries, you don't know who is going to get on your pip.
Posted: Sun Feb 10, 2008 1:37 pm Post subject: |
Yes just follow the same routine, although I bet by now you will have tried it and found it works - Mike |
Gee-Pee Lifetime Member
Joined: Feb 10, 2005 Posts: 1951 Location: Mostly somewhere in Essex
Posted: Sun Feb 10, 2008 2:01 pm Post subject: |
Martin4Jay wrote: | mikealder wrote: | Select csv and then continue to make your POI selection, finally you then select the download to get the files you require, do not refresh the page as that will reset it back to default - Mike |
Martin |
I presume you have already followed this 'How to' help sheet on this page but I would be curios to know if the S range has the same system as the N range
The 'note' in red under No 4., is critical _________________ Gee-Pee
Lifetime member PGPSW - time rapidly decreasing |
Posted: Sun Feb 10, 2008 5:34 pm Post subject: |
Gee-Pee wrote: | Martin4Jay wrote: | mikealder wrote: | Select csv and then continue to make your POI selection, finally you then select the download to get the files you require, do not refresh the page as that will reset it back to default - Mike |
Martin |
The 'note' in red under No 4., is critical |
Yes Gee-Pee I did read it but I was not sure how to do it sorry I'm not that brainy.
Many thanks
Posted: Sun Feb 10, 2008 5:59 pm Post subject: |
So have you actually got the required POI files on the device yet, or are you still having problems? - Mike |
Posted: Sun Feb 10, 2008 6:12 pm Post subject: |
mikealder wrote: | So have you actually got the required POI files on the device yet, or are you still having problems? - Mike |
Thanks Mike I'm going to wait for my friend to show me what to do as I can watch and learn.
