Pocket GPS World :: View topic - Copy POI's to 310 SD card only
ozsat
PostPosted: Tue Jan 08, 2008 5:47 pm    Post subject: Copy POI's to 310 SD card only Reply with quote
Apologies if this is covered - I've seen it mentioned but not been able to get it to work.
Several people suggest copying POIs to the SD card rather than uploading them via POILOADER.
How is this done as I can not seem to get POIs on the SD card to be seen.
I'm using the nuvi 310 Deluxe with standard SD card.
PaulB2005
PostPosted: Tue Jan 08, 2008 5:49 pm    Post subject: Reply with quote
You still need to use POILoader to load them onto the SD Card. It can't be done directly. This is because POILoader collates the POIs into one big file called POI.GPI and then loads it to the SD Card.
You need to have the SD card in a card reader in your PC and tell POILoader to load them to the card.
ozsat
PostPosted: Tue Jan 08, 2008 6:13 pm    Post subject: Reply with quote
Got it - thanks.
The SD card is the next drive up from the nuvi in POILOADER
ozsat
PostPosted: Tue Jan 08, 2008 6:16 pm    Post subject: Reply with quote
Apart from "being available if the SD card is removed" - is there any benefit in just leaving them on the SD card and not copying them to the unit?
