Darren Frequent Visitor
Posted: Thu Dec 20, 2007 6:52 pm Post subject: |
So long as you have a full backup via Explorer then there is little risk in trying. Most issues occur when a user has only a HOME update and the restore doesn't always work
I have a number of GO's and have never had an issue updating via HOME so it's not that common a problem albeit annoying when it does happen.
Backup once again to another folder as a precaution and all will be well _________________ Darren Griffin |
anditsinthere Occasional Visitor
Posted: Thu Dec 20, 2007 6:59 pm Post subject: |
Darren,
What is the first thing i do when i take my 520T out of the box? Do i back it up using 'Removable Disk' in my computer then copying all the contents to a separate file on my desktop?? BEFORE i download anything??
Thanks |
Posted: Thu Dec 20, 2007 7:02 pm Post subject: |
anditsinthere wrote: | Darren,
Thanks |
That's the best procedure, plug it in, create a folder on your PC and then using Explorer copy EVERYTHING from the Go to the folder you created. _________________ Darren Griffin |
Posted: Thu Dec 20, 2007 7:05 pm Post subject: |
So after i have copied everything, would it be then safe to download maps, speed cameras? i did this with the one i have just sent back but i got the red cross? Are you not meant to download before backing up first? |
Badgerman26 Occasional Visitor
Posted: Thu Dec 20, 2007 7:06 pm Post subject: |
Darren wrote: | anditsinthere wrote: | Darren,
Thanks |
That's the best procedure, plug it in, create a folder on your PC and then using Explorer copy EVERYTHING from the Go to the folder you created. |
Yep defo, that has just saved my xmas morning! I am just backing them up to an external HDD and CDR as I type! _________________ TT Go 520
Fabia Vrs (Mine)
VW Golf (the wifes) |
Posted: Thu Dec 20, 2007 7:24 pm Post subject: |
anditsinthere wrote: | So after i have copied everything, would it be then safe to download maps, speed cameras? i did this with the one i have just sent back but i got the red cross? Are you not meant to download before backing up first? |
As long as you have a backup of the device as it was when it came out of the box you can 99.9% of the time recover from anything except a hardware failure. _________________ Darren Griffin |
Posted: Thu Dec 20, 2007 8:16 pm Post subject: |
Okay so i got my new Tom Tom 520 in front of me, the connection to click onto removable disk (f) is very slowwwwwwwww....the egg timer is constantly on!!!!! |
Posted: Thu Dec 20, 2007 8:36 pm Post subject: |
When i click on Removable disk (f) on My Computer it says please insert disk into f? Do i click on the Tom Tom icon (g)? instead? Nothing happens when i click the removable media icon?? Please help.... |
if1977 Lifetime Member
Posted: Thu Dec 20, 2007 8:47 pm Post subject: |
Quote: | When i click on Removable disk (f) on My Computer it says please insert disk into f? Do i click on the Tom Tom icon (g)? instead? Nothing happens when i click the removable media icon?? Please help.... |
if you bring up the my computer page and then connect your TT to you PC with the USB cable you will see what removable drive it is and click that icon and that should bring up the root of your TT. If it is slow try closing other apps you are running and see if that helps. _________________ NEW Tomtom GO 500 (hope it is good)
iphone (running all day, doesn't like it)
XL LIVE IQ Routes (Got stolen and miss it)
GO 510 (in drawer now, time for upgrade) |
Posted: Thu Dec 20, 2007 9:15 pm Post subject: |
Its the Tom Tom icon (g) that all the files are in, i have copied them to a folder on my desktop and then to a 1GB usb drive. Hope that now i can download things??? |
Oldboy Pocket GPS Moderator
Posted: Thu Dec 20, 2007 10:08 pm Post subject: |
Most PCs will display the Drive Letter with TomTom as the Drive Name. So as you found out G: is right for you.
F: was slow because Windows was searching for the Disk/Media in that Drive and trying to work out what it was. In the end it would have come up with an error message.
You have done it correctly.
It is best to only download, and change, one thing at a time. That way you can check to see if it is working OK before going on to the next step.
If it's a Map, or a Software Upgrade, I always do another Backup if it's working OK, before moving on to the next one.
(That reminds me ..... must get rid of some of the older backups that are no longer usable.) _________________ Richard
DennisN Tired Old Man
Posted: Thu Dec 20, 2007 10:13 pm Post subject: |
Oldboy wrote: | (That reminds me ..... must get rid of some of the older backups that are no longer usable.) | Me three!! I've just shifted 60GB of various Tom Tom Backups onto my external HDD. _________________ Dennis
Two of them are obesiting!! |
Posted: Thu Dec 20, 2007 10:57 pm Post subject: |
Oldboy wrote: | Most PCs will display the Drive Letter with TomTom as the Drive Name. So as you found out G: is right for you.
I have backed up to usb drive and a file on my desktop, i was going to run the automatic updates from HOME but i didnt download anything just in case it went t!ts up! i had a load of updates with loads of camera updates like this Safety cam FR Safety cam IT and at the bottom Safety cam UK i presume i untick all the boxes and click the UK one?? Oh and there was an update for GB and Ireland maps....what should i update first? |
Posted: Thu Dec 20, 2007 11:12 pm Post subject: |
You could download the speed cam one first as this takes seconds and then the maps one as it takes about 45 minutes if it is the GB one. _________________ NEW Tomtom GO 500 (hope it is good)
Andy_P Pocket GPS Moderator
Posted: Thu Dec 20, 2007 11:29 pm Post subject: |
If you have bought a UK map before, I think you will find the one it is offering you is the one you HAVE ALREADY. (Check the version number).
This is a known bug with Home - I am still offered an old v6 UK map for my old Go300 every time I connect my Go720 to Home.
As for the camera files, yes you are right, just untick everything except the UK ones, it's another "feature" that it doesn't remember your preferences and you have to do this every time. |
