Pocket GPS World :: View topic - Whats Going on 'ere Then
LesP2008
PostPosted: Wed Dec 12, 2007 7:26 pm    Post subject: Whats Going on 'ere Then Reply with quote
Yesterday i put the new 710 maps onto my device, a 910. It's wierd as when i put the application on my device 7.162 before the new maps it was 13 mb or so. Now with the new maps i reinstalled the app because my menu had no help icon visible. My father in law has the same set up and he has a help icon. On reinstallation i still have no icon but the app has shrunk to 10.9 mb.
Wierd!, or is it just another anomoly from HOME.
PostPosted: Wed Dec 12, 2007 7:39 pm    Post subject: Reply with quote
Are you running a custom Menu per chance, if so it will be this that is causing the problem with HelpMe and probably MapShare, look in the SdkRegistry folder and locate the file named TomTom.mnu, remove it and the two functions should both appear, next you will be saying the HelpMe guides such as first aid and country information don't work I think - Mike
LesP2008
PostPosted: Wed Dec 12, 2007 7:46 pm    Post subject: Reply with quote
Hi Mike, What are you a mind reader LaughingI heard the thing doesn't work anyway. Andy helped me yesterday with the mnu thing, however my icon for poi capture is still there. I will root around and see if i can sort it. Thanks for the help.
LesP2008
PostPosted: Wed Dec 12, 2007 7:59 pm    Post subject: Reply with quote
Mike, Thanks so much it is all shipshape now. I noticed you pointed me too the SDK mnu. There it was. Deleted it and loaded the zipped file and off it went.
Thanks again.
PostPosted: Wed Dec 12, 2007 8:03 pm    Post subject: Reply with quote
I do have a few crystal balls but they are getting close to needing replacing!!
Seriously though if there is anything at all in the SdkRegistry folder it will prevent the true menu from displaying thus giving you the problem you have!, what I would do is remove the contents of the SdkRegistry folder by copying them to your PC before deletion then try out the HelpMe function, once you have read through it put the SdkRegistry folder contents back on the device and forget about the contents, you will know what I mean when you have viewed it - Mike
Oldboy
PostPosted: Wed Dec 12, 2007 8:36 pm    Post subject: Reply with quote
I find it easier just to take 1 letter out the SdkRegistry name. Saves moving it. Wink
22.053 (15 May 24)
