Pocket GPS World :: View topic - Rider 2 battery cable - how to fit
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Motorcycle GPS Users
Tarby777
PostPosted: Sat Dec 01, 2007 9:27 am    Post subject: Rider 2 battery cable - how to fit Reply with quote
Hi all,
My Transalp will be in for a service next week and I want them to fit the battery cable for my TTR while they're at it. They haven't done one before and they're not keen to attempt it without some proper guidance. There's nothing much in the TTR manual, or the Tomtom website.
I know that several of you have done it because of all the posts you make about power problems! What's the best way to do it?
TIA
Tarby
Tim Buxton
PostPosted: Sat Dec 01, 2007 9:50 am    Post subject: Reply with quote
I have mine wired so that it's live all the time, but that's only because my Triumph has a connection ready for such a thing. A better way might be to wire it so that it's only live with the ignition on. Either way, don't forget an (easily accessible) inline fuse. 1A should be enough.
Tim
PostPosted: Sat Dec 01, 2007 10:03 am    Post subject: Reply with quote
Crikey, not very encouraging when a dealer is unable to perform a simple accessory install like this!
It's a simple 12v fused feed. Preferably wired to an ignition controlled source but then again, you're hardly likely to leave your RIDER plugged in when the bike isn't being used so a straight fused connection to the battery might be just as suitable.
Darren Griffin - Editor
Tarby777
PostPosted: Sun Dec 02, 2007 4:42 pm    Post subject: Reply with quote
Thanks guys. I was wondering... can you safely leave the dock attached to the bike at all times - even when the TTR isn't there? I'm just wondering how weather-proof the dock is...
TIA
Tarby
PostPosted: Sun Dec 02, 2007 4:56 pm    Post subject: Reply with quote
yes, it's designed to be left on and is fully weatherproofed.
Tim Buxton
PostPosted: Mon Dec 03, 2007 9:37 am    Post subject: Reply with quote
Bear in mind that the dock could be easily stealable, depending on which mount option you use. Is it a RIDER or RIDER2?
Tim
Tarby777
PostPosted: Mon Dec 03, 2007 10:24 am    Post subject: Reply with quote
It's a Rider 2.
Tim Buxton
PostPosted: Mon Dec 03, 2007 10:35 am    Post subject: Reply with quote
Tarby777 wrote:
It's a Rider 2.
If you're using the Ram mount 4" arm then you can get a locking device which either covers or replaces the thumb wheel. It will add peace of mind and I'll be getting two (due to the way I've mounted mine) if I ever tour on the bike again. Generally the bike is parked in view or on secure land; with touring this isn't always an option.
Tim
jaybeblue
PostPosted: Mon Jan 28, 2008 10:47 pm    Post subject: Reply with quote
Please see my post at http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=63854
jaybeblue
PostPosted: Tue Jan 29, 2008 10:39 pm    Post subject: Reply with quote
If you've got a BMW F800 there are some wiring instructions at http://www.f800riders.org/forum/showthread.php?t=10013. This enables you to wire the GPS into the CANBUS.
RebelYell
PostPosted: Sat Aug 16, 2008 9:56 am    Post subject: Reply with quote
I installed one of those little car safes in my top box and lashed the brided wire cable around the top of the right hand damper. It's just big enough to get the rider and dock in.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Motorcycle GPS Users All times are GMT + 1 Hour
21.115 (29 Nov 23)
