Pocket GPS World :: View topic - garmin etrex gps versus toshiba e330 pda
snuitsma
PostPosted: Mon Apr 05, 2004 5:41 pm    Post subject: garmin etrex gps versus toshiba e330 pda Reply with quote
Is it possible to connect a garmin etrex to a toshiba e330 pda via a serial cable? I can imagine that it's possible to connect the serial cable of the etrex to the serial cable of the toshiba via a straight or cross connection but does gps software recognize the gps receiver in this way?
Greetings.
Tim Buxton
PostPosted: Mon Apr 05, 2004 6:26 pm    Post subject: Reply with quote
I can't say for your combination, but it has certainly worked in my case. I've had my Garmin GPS V talking to my iPAQ 3970 which was running MS PocketStreets.
Tim
snuitsma
PostPosted: Mon Apr 05, 2004 9:51 pm    Post subject: Re: garmin etrex versus toshiba e330 Reply with quote
Tim, how did you do the connection? Just connect the two pc cables of both devices to each other (with or without cross)?
But youre cable made connection between the ipaq en the garmin? Was it also a serial connection? Did it need drivers on the ipaq or did the software just recognize the gps receiver?
Thanks.
Tim Buxton
PostPosted: Tue Apr 06, 2004 4:45 am    Post subject: Reply with quote
I used the Garmin serial port cable and the iPAQ serial port cable with a crossover in the middle. If you think about it, both cables contain a crossover, so you need a third one to actually cross the data. PocketStreets comes with GPS support I think. If not, it is a free add-on. That's all I used. The only limits are that PocketStreets doesn't support routing and the mapsize is also limited, though I don't know to what size.
Tim
snuitsma
PostPosted: Tue Apr 06, 2004 7:24 pm    Post subject: thanks Reply with quote
Thanks, I will test this.
Wouter.
