Pocket GPS World :: View topic - tomtom one sd help
tomtom one sd help
Goto page Previous  1, 2
sharky007
PostPosted: Sat Sep 22, 2007 8:45 pm    Post subject: Reply with quote
yes you can see and use the map
and it does not need activating if you switch to another map then back again
but it will not come up with all the maps
why is this
cheers
PostPosted: Sat Sep 22, 2007 9:02 pm    Post subject: Reply with quote
sharky007 wrote:
this is what i have exactly on the memory card
canary islands
australia
usa &canada
western europe
Are you sure you have the right names for the Folders?
USA & Canada is called North_America. Confused
Probably your best course is to wipe the SD Card and copy the Application, and the Map, that is the Internal Memory, to the Card.
Then use the Card to make sure that it works OK.
Then you can think about Installing the other Maps. They are designed to be installed with HOME. How are you doing it?
sharky007
PostPosted: Sat Sep 22, 2007 9:32 pm    Post subject: Reply with quote
i have a 1gb card with usa on it and it works
i added the application and all the other off iternal memory and it works with western europe and canary islands but when i add usa & canada and australia its like there not there im just adding them to the sd card as i cannot add them through home unless you pay and download them from tomtom
all i want to do is copy everything off internal add a couple more maps so its on the 4gb card so i will have some room left
thanks
Wazza_G
PostPosted: Sat Sep 22, 2007 10:52 pm    Post subject: Reply with quote
I've been reading this thread and didn't you say that you have a 4Gb SD card?
If so that may well be the problem, afaik the maximum size supported is 2Gb.
I know I've seen a few people say they've got a 4Gb card to work, but they seem to be the exception rather than the rule.
sharky007
PostPosted: Sun Sep 23, 2007 8:29 am    Post subject: Reply with quote
ni it shuold work because i phoned tomtom and they said a 4gb card is fine
Wazza_G
PostPosted: Sun Sep 23, 2007 9:44 am    Post subject: Reply with quote
With TT's reputation, I'd take that advice with an extremely unhealthy pinch of salt! Sad
PostPosted: Mon Sep 24, 2007 12:28 am    Post subject: Reply with quote
Was very suprised this thread had got so far before any one mentioned the card size...
2GB is the normal maximum. SOME 4GB cards work but they MUST NOT be HDSC (which most are).
If you use the "search" facility and type "4GB SD" in the box (limit the search to the TomTom section), you will get the names of 2 4GB cards that DO work.
Moral: Never trust TT customer support to give you the right answer.
Page 2 of 2
22.052 (08 May 24)
