Pocket GPS World :: View topic - TTG520
TTG520
Goto page Previous  1, 2
technik
PostPosted: Sat Aug 25, 2007 9:37 pm    Post subject: Reply with quote
Most people have found that you have to use TomTom Home to copy the MP3 files, as otherwise they are not recognised.
bazzza
PostPosted: Sat Aug 25, 2007 10:10 pm    Post subject: Reply with quote
Would someone be kind enough to explain how this is done. I have searched the Manual and Home help and nothing explains it. The manual refers me to Home and Help in Home tells me I can do it but not how.
I have now deleted everything on my SD card and my Mp3 files are on the computer in a folder called Mp3. Where do I go from here?
Bazzza
TTGO520 Version 9.430
Western & Central Europe Maps
Iphone 6
TT Via 135M
GO520 WiFi
mikeossy
PostPosted: Sat Aug 25, 2007 10:29 pm    Post subject: Reply with quote
iirc the go has 2gb mem anyway so goto your software (TTG Home) switch on your TT and select arrow till you get to update voices maps etc then press the arrow again and you should get to update songs or playlist or something like that then basically drag and drop the files (there is a kinda tutorial from here) from your pc onto the 'harddrive' of your Go. It will open another explorer window labeled something like drive K or L or M depending on how many removalable drives you have - hope that helps.
TTG 720 with TT Home edition 2.0
Nokia N95 for GPRS Weather and Traffic updates.
bazzza
PostPosted: Sat Aug 25, 2007 11:03 pm    Post subject: Reply with quote
Thanks Mike. That worked. Only problem is that it only allowed me to load 41 mp3 tracks and it then told me that the receiving folder was full.
Any clues?
ps. What is the SD card slot for?
Bazzza
Iphone 6
TT Via 135M
GO520 WiFi
xda
PostPosted: Sun Aug 26, 2007 12:15 am    Post subject: Reply with quote
Any clues?
That is because you have loaded them into the Go's memory.
Put a 1GB or 2GB SD Card into your SD Card Slot and load the MP3 tracks onto the SD Card. I have 21 complete CD's on mine.
Graham.
Map: Europe V910.4892
Nokia 925 Windows 8
bazzza
PostPosted: Sun Aug 26, 2007 5:51 pm    Post subject: Reply with quote
I tried that before but TT doesn't seem to detect them. I put the files onto an SD card by putting the card into the PCs SD slot and copying them from a file on the PC. Should I be using Home to put them on the SD card? If so,how?
Bazzza
Iphone 6
TT Via 135M
GO520 WiFi
PostPosted: Sun Aug 26, 2007 6:14 pm    Post subject: Reply with quote
I only use Windows Explorer to install mp3 files to the mp3 folder on the card, I notice you have named the folder Mp3 in a number of previous posts, you need to drop the caps from the folder name, the TomTom will not see a folder named Mp3 but it is happy to use mp3
The other issue could be down to card speed, does the device boot up with the card intalled, if it does you don't have a problem with card speed - if it fails to boot up with the card inserted you might need a newer faster card - Mike
bazzza
PostPosted: Sun Aug 26, 2007 7:28 pm    Post subject: Reply with quote
Problem solved. 1GB SD card seemed ok so I put a folder on it called "mp3" (No caps) using explorer, plugged the Sd card back into the TT and it works fine. I think the capital M was the problem.
"What's next?" indeed. Thanks.
Bazzza
Iphone 6
TT Via 135M
GO520 WiFi
xda
PostPosted: Sun Aug 26, 2007 11:05 pm    Post subject: Reply with quote
Looks that way Laughing
At a guess I would say a HTC Advantage.
Graham.
Nokia 925 Windows 8
PostPosted: Mon Aug 27, 2007 7:12 am    Post subject: Reply with quote
[quote="xda"]
I already have the T-Mobile Ameo which is the silver version of the Advantage, I have had this four months Laughing - Mike
PostPosted: Mon Aug 27, 2007 8:22 am    Post subject: Reply with quote
[quote="mikealder"]
A new Ovlov, predrilled with 19 holes and a blank honeycomb dashboard?
Page 2 of 2
22.054 (22 May 24)
