Pocket GPS World :: View topic - TomTom ONE: No voice
geoffowen
PostPosted: Thu Aug 23, 2007 9:15 pm    Post subject: TomTom ONE: No voice Reply with quote
Like many 1st time posters, I have a problem Sad
I have no voice on my TT1. This has happened a few times and I put it down to the level of charge (assuming low charge meant no voice to conserve battery). I hadn't used the TT1 for a long period and guessed it had pretty much lost all its charge.
However, I've now been using it for about a week and so it should be charged. And yet still no voice. I've checked the card and the voice files appear intact, so am at a loss to why they don't work.
Any help would be very much appreciated.
Geoff
PostPosted: Thu Aug 23, 2007 9:26 pm    Post subject: Reply with quote
Have you tried a Reset?
Have you tried Selecting a voice in Change Preferences?
geoffowen
PostPosted: Thu Aug 23, 2007 9:30 pm    Post subject: Reply with quote
Both. No joy. 'Test' gets me nothing, fiddling with vol - no effect Mad
PostPosted: Thu Aug 23, 2007 9:33 pm    Post subject: Reply with quote
The volume is not turned down, or the Sound Muted in Change Preferences?
geoffowen
PostPosted: Thu Aug 23, 2007 9:50 pm    Post subject: Reply with quote
Neither, I've checked and double checked.
On reflection, I should add that the voice has kicked back in the last time this happened after about 6 hours use (hence my assump that it was battery related). But as abive, i've been using it for a week now with no joy.
PostPosted: Thu Aug 23, 2007 9:54 pm    Post subject: Reply with quote
The sound icon in change preferences has got a Red Cross through it?
When you go to Change Voice are the graphics Black, or Grey?
geoffowen
PostPosted: Fri Aug 24, 2007 10:55 am    Post subject: Reply with quote
I've toggled the sound on and off but that has no effect. As I recall (am sat at my desk ATM) it normally has the option to 'turn off sound' displayed, which, when selected, shows a 'no sound' icon on the route display. This icon is not normally present, so I guess I haven't got the sound switched off.
I have both default UK voices available (US voices 'require installation') and can select either - but 'Test' produces nothing.
PostPosted: Fri Aug 24, 2007 11:29 am    Post subject: Reply with quote
I also wonder if there is a problem with the vif File.
The vif File should look like this, in Notepad.
English(UK) - Tim
data04.chk
Tim
2
0
110
3
How big are the data04 and data05 chk Files? Should be 671KB and 660KB.
TVR
PostPosted: Fri Aug 24, 2007 11:59 am    Post subject: Reply with quote
Is it's serial no. E22486H10547 ? if it is it went for repair, then lost in post and then found 4 months later!
I had the same problem with my TT1V2 earlier this year. (Read about it Here). Does this appear to be the same problem?
Sounds to me (no pun intended) that it's time for a repair or take it back for a new one (if your still inside your guarenttee period). I'd insist on the latter.
Good Luck!
TVR
Sygic for android in HD
Cameralert - pending
TomTom consigned to the bin, after 6 years loyal service.
View user's profile Send private message Yahoo Messenger MSN Messenger
geoffowen
PostPosted: Fri Aug 24, 2007 12:55 pm    Post subject: Reply with quote
TVR thanks for the link (I had searched but didn't find that thread). Doesn't look good. (BTW you and I share a birthday.)
Oldboy, I shall check as you suggest and get back.
Thanks for your help.
geoffowen
PostPosted: Fri Aug 24, 2007 4:47 pm    Post subject: Reply with quote
671 and 660 respectively.
The content of my data 4 file (Tim) was:
English(GB) - Tim
data04.chk
Jane is similar.
I changed it to the settings suggested by oldboy (using notepad, tried ANSI and Unicode formats), but still no joy (ie sounds on, test Tim produces nothing).
Just to confirm, both Tim and Jane are black (others are grey).
geoffowen
PostPosted: Fri Aug 24, 2007 4:57 pm    Post subject: Reply with quote
Installed a few extra voices from CD - nothing.
geoffowen
PostPosted: Fri Aug 24, 2007 5:03 pm    Post subject: Reply with quote
UPDATE: just shot it with 9v instead of 5 (by mistakenly plugging in the wrong adaptor). Result: unit seems to have died. Got a green charge light, but screen won't come on...
22.052 (08 May 24)
