Pocket GPS World :: View topic - TomTom Rider Route logging
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Motorcycle GPS Users
dazzajones
PostPosted: Sun Aug 12, 2007 3:27 pm    Post subject: TomTom Rider Route logging Reply with quote
Does anyone know how i can track my route on the rider and then import it into a program on my pc (like autoroute, maybe by using itn convert).
Also doe sthe new ttr v2 automaticaly track routes?
PostPosted: Sun Aug 12, 2007 5:11 pm    Post subject: Reply with quote
Do you mean you want to record where you have been for post analysis? if so you could try installing NMEA Logger then import the data to the PC using something like GPS Babel to get the data into the required format - Mike
dazzajones
PostPosted: Sun Aug 12, 2007 5:52 pm    Post subject: Reply with quote
Thanks for the reply.
I basicaly want to turn the TTR on, go for a ride on 'new' roads, get home, plug in TTR, import to Autoroute or similar and see where ive been.
Now im not sure what nmea files are but ill look into it and see what i can do with that program.
Thanks for the suggestion.
PostPosted: Sun Aug 12, 2007 6:57 pm    Post subject: Reply with quote
NMEA data is the actual output from the GPS device which updates at a rate of once per second, NMEA logger will record the position, speed etc every second of your trip as a text file, they are quite small - I use a rough rule of thumb that one hour of logging equates to 1MB file size.
Once you have the txt file you use the other application I mentioned to convert the file to whatever you need to display the file using another mapping application on the PC - Mike
dazzajones
PostPosted: Tue Aug 14, 2007 6:35 pm    Post subject: Reply with quote
Mike, thanks again for your help. I couldnt get along with the nmea logger etc, however i did find the 'tripmaster' program off that site you mentioned and this does what i want.
Thanks again.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Motorcycle GPS Users All times are GMT + 1 Hour
21.021 (01 Feb 23)
